problem with the C# code
YashuAsha
@yashuasha-I5vI1n โ€ข Oct 25, 2024
Hello,
I am new to C#. i have written a function (method) in C# to connect with the SQL Database. if the UserID and Designation is true then it has to go for appropriate aspx page in C# but i am not getting how to call that method
i have table Users which consists of UserID(datatype as varchar) ,Password (datatype is varchar) and Role (datatype as varchar)
here is the code
namespace MyKlaus
public class AllFunctions
public static object DBconnection(string UserID, string Password)
try
SqlConnection con = new SqlConnection(@"Data Source=localhost\sqlexpress;Initial Catalog=klauDB;Trusted_Connection=true");
SqlCommand cmd = new SqlCommand("SELECT Username,Password from Login where Username='" + UserID + "' and Password='" + Password + "'", con);
con.Open();
SqlDataReader dr = cmd.ExecuteReader();
if (dr.Read())
HttpContext.Current.Response.Redirect("HomePage.aspx");
else
HttpContext.Current.Response.Write("<script type='text/javascript'>alert('Login Failed!')</script>");
HttpContext.Current.Response.Flush();
con.Close();
catch
return null;
  • Neeraj Sharma
    @neeraj-iAaNcG Aug 1, 2012
    Can you please post in your code so that we can have a look at the issue more clearly
  • simplycoder
    @simplycoder-NsBEdD Aug 2, 2012
    try using Convert.ToBoolean(...)
    this is a wild guess from your question,
    if this doesnt work, kindly post the code which you think causes the problem.
  • YashuAsha
    @yashuasha-I5vI1n Aug 2, 2012
    Nick_SharmaCan you please post in your code so that we can have a look at the issue more clearly
    thank you, I have made mistake in giving the parameters this error (cannot implicitly convert int into bool) is solved.
    i have posted the code. i am not getting how to call DBconnection function. Can anyone help me
  • YashuAsha
    Also i am getting error as DBconnection(string, string) not all code paths returns a value
  • simplycoder
    @simplycoder-NsBEdD Aug 4, 2012
    You are missing some return statement.
    Please Post the relevant code.
