PowerPad 16: A 16 Port USB Charging Dock For Your iDevices
Swagatam M
@swagatam-m-lRtOc7 โ€ข Oct 12, 2024
Are you from the iFamily? What I actually mean is, have your family got more Apple devices like a couple of iPhones, iPads and iPods? If yes, then you must be definitely fighting for charging them all at a time when you need to go on a long vacation, where you don't know you'll get enough charging points or not.
<a href="https://www.ipadcarts.com/solutions/DS-IP-PP16.htm" target="_blank" rel="nofollow noopener noreferrer">USB hubs to sync, charge, secure iPads and many tablets</a>. now has the perfect solution for you, the PowerPad 16. As the name suggests, this USB charger can charge up to 16 devices at a time. Each of the 16 USB ports provides 2.1A current, which is the optimum charge level needed for charging the iDevices. Well, what we think is 16 ports is a bit too much for a household use. This product will find greater application and use in more enterprise environments like offices, schools & colleges, airports and even in bigger conferences like MWC or CES, etc.
This portable USB charging hub measures 6.75 x 3.75 x 2.2 inches in dimension and can be mounted anywhere with the four screw holes provided. The charging dock is fitted by Cambrionix board and a cooling fan on one side to keep the hub running cool. The hub can charge any USB powered device given that they can be charged from Apple's USB AC adapter as it is not an universal charging dock. Datamation Systems is working on making other version of this product which could accommodate other USB devices too. The price detail of the product is still unknown but be assured that this won't come cheap.
