Designing Compressed Air Pipework for Long Production Runs: Avoiding the Pressure Drop Trap
ShiftAir Transmission Pvt. Lt
@shiftairtransmission
Published: Oct 4, 2026
Updated: Oct 4, 2026
Hello Engineers,
We've all seen it on the factory floor: a compressor running perfectly fine, but machines at the far end of a long production line are starving for air.
More often than not, the issue isn't the compressorโ€”it's the pipework design. For long production runs, poor piping design leads to excessive pressure drop, which wastes energy and ruins tool performance.
Here are a few fundamental engineering principles we should keep in mind when designing these systems:
๐Ÿ”น Keep Pressure Drop โ‰ค 0.1 bar: This is the golden rule. If you lose more than 1.45 psi from the compressor to the most remote point of use, your equipment won't operate efficiently.
๐Ÿ”น Use a Ring Main (Loop) System: A dead-end piping layout will always cause low pressure at the furthest points. A ring main allows air to reach any point from two directions, balancing the pressure across the entire loop.
๐Ÿ”น Size for Flow and Distance: Don't just size the pipe based on the compressor outlet. Check your air velocityโ€”keep it below 20 ft/s in main headers and below 30 ft/s in distribution lines to prevent friction losses.
๐Ÿ”น Proper Air Treatment: Ensure dryers, filters, and condensate drains are correctly placed. Always use top take-offs from the main line to prevent water carryover into your machinery.
I recently came across a highly detailed, step-by-step guide on how to execute this properlyโ€”covering everything from establishing a pressure-drop budget to choosing the right materials (Aluminum vs. Copper).
