    @ramani-VR4O43 • May 10, 2016
    Almost all exercise bikes use adjustable friction pads to vary the resistance. Consider designing a bike with a generator. Resistance can be adjusted by adjusting the charging current to a storage battery. Bonus: the user gets some stored power forthe effort put in.
  • vishal deokar
    @vishal-hv6Ebo • May 10, 2016
    thank you sir
    you mean bike generated power is use to offer resistance. resistance increase or decrease with ratio of speed or force applied
    What I mean is that if the bike is linked to a generator it can generate power, which will be available for other purposes. However, an exercise bike should have a variable resistance so that the user can adjust the effort. What has to be designed is the power train linking the bike to the generator so that at a higher setting more power will be generated. I think that a commercially available variable gear for bikes may be sufficient.
    At higher setting a larger charging current will be available.
  • vishal deokar
    thanks GURU,
    i will going to study on it.
