need urgent help - accelerometer set up
singhp2
@singhp2-vkOFRV โ€ข Oct 23, 2024
I have two dual axis ADXL203 accelerometers. However, I am supposed to get acceleration data in three dimensions. My professor advised me to get dual axis instead of triaxial accelerometers becuase of the easier soldering process.
How should I set up the two accelerometers to get three dimensional data?
I really need some help.
Thank you in advance
    @harshad-ukH5ww • Mar 31, 2009
    rather than creating Confusion... Its better to use the triaxial accelerometer directly.
  • singhp2
    singhp2 OP
    @singhp2-vkOFRV • Mar 31, 2009
    that is what i wanted to do...but my professor really didn't want me to use the triaxial ones because of the difficulty in soldering...so I don't have a choice but to use dual axis accelerometers...my deadline is approaching soon ๐Ÿ˜”...any help please
  • sauravgoswami
    @sauravgoswami-UAfTlI • Apr 3, 2009
    well soldering difficulty cant be the reason for not using tri-axial accelerometer,you can use a connecter instead of directly soldering!!!
  • Ashraf HZ
    @Ash • Apr 8, 2009
    I know this might sound obvious, but try putting one of the accelerometers on its side so one of its axis aligns with the Z axis. The issue you'll have is calibrating the output properly. One way is to just toss the circuit down and see if it really measures 9.81 ๐Ÿ˜‰
