@harshad-ukH5ww • May 24, 2011
You can Use KEIL which is Compiler and Simulator. -
@the-small-k • May 24, 2011
Actually i have some hands on 8051 with assembly language programming.And now i want to use c.Is it good to go with 8051 in starting or i have to switch over atmel(which is widely used these day for embedded projects). -
ATMEL's AT89C51 is similar to your 8051 which you have studies in syllabus. So you can go with ATMEL and KEIL. 😀The_Small_kActually i have some hands on 8051 with assembly language programming.And now i want to use c.Is it good to go with 8051 in starting or i have to switch over atmel(which is widely used these day for embedded projects).
