Linux command for copying a file from remote server location to our local machine
Nikumbh
@nikumbh-lmTCgS โ€ข Oct 23, 2024
scp -r testuser@10.0.5.215:/home/testuser/tmp/hello.txt /home/elcot/hello.txt
I've used the above command to copy the file located at the server:10.0.5.215, location: /tmp/hello.txt username: testuser to my local machine local-username: elcot....
Could anyone help me to get the file located remotely....
  • lovejeet
    @lovejeet-etHdkD Aug 9, 2013
    can you post the error you are getting?? try using rsync cmd, which runs over ssh protocol and furthermore provides a lot of configurable parameters.
  • Nikumbh
    @nikumbh-lmTCgS Aug 9, 2013
    #-Link-Snipped-# : i was getting connection timed out msg.... i don't know why. ๐Ÿ˜”
  • lovejeet
    are u able to ping to the server??
  • Nayan Goenka
    @nayan-Dhpt4N Aug 10, 2013
    Just verify if you have healthy connection to the server. Apart from that if this is some kind of backup utility, I would suggest you to use rsync to take network backup for sharing files. It is secure as well
