JAVA codes for Image Comparison
GULNAZ KMT
@gulnaz-kmt-fHFb0M โ€ข Oct 26, 2024
Hi.. Am looking for appropriate java codes for Comparing images.. I searched thru net but no apt codes related 2 it.. Anybody 2 help me out thre???๐Ÿ˜”
  • Reya
    @reya-SMihdC • Dec 20, 2010
    You mean to compare two images whether they are equal?
  • GULNAZ KMT
    @gulnaz-kmt-fHFb0M • Dec 20, 2010
    Yup.. Irrespective of size of the image, I need to write a JAVA code, where it'l compare the image given as an input with another image already contained in my database and return true if comparison matches. For Eg., if I give an image of computer, my code should be able to compare with images of computer in my database and return the o/p.. Database codin part, leave it upto me. I just need help in, how Java compares two images..
    @abrakadabra • Dec 21, 2010
    Hi Gulnaz,
    I searched for your query on the net and found this result:
    <a href="https://mindmeat.blogspot.com/2008/07/java-image-comparison.html" target="_blank" rel="noopener noreferrer">Mind Meat: Java Image Comparison / Motion Detection</a>
    Does that help?
    Here is some information about processing pixels in an image using Java :
  • Morningdot Hablu
    @morningdot-6Xuj4M • Dec 27, 2010
    Sorry for late reply actually i am busy in exams.
    Well i have an idea how to compare two images check this code.
    Use it to compare two images hope it works.But it's just an idea you can edit it on your own way.
    import javax.swing.*;
    import java.io.*;
    import java.awt.*;
    import java.awt.event.*;
    /*<Applet code="comp" height=400 width=400></applet>*/
    public class comp extends JApplet implements ActionListener
    Button b;
    String str,str1;
    public void init()
    b=new Button("submit");
    add(b);
    setLayout(new FlowLayout());
    b.addActionListener(this);
    public void actionPerformed(ActionEvent e)
    repaint();
    byte b1[]=new byte[60000];
    byte b2[]=new byte[60000];
    try
    int i=0;
    FileInputStream f1=new FileInputStream("kk.jpg");
    f1.read(b1);
    FileInputStream f2=new FileInputStream("kk1.jpg");
    f2.read(b2);
    while(b1!=3 || b2!=3)
    if(b1==b2)
    i++;
    else
    str="not matched";
    break;
    if(b1[i-1]==b2[i-1])
    str="matched";
    str1=Integer.toString(i);
    catch(Exception ee)
    System.out.println("Exception caught");
    public void paint(Graphics g)
    g.drawString(str,100,100);
    g.drawString(str1,200,200);
