IR Switching.
klaatu
@klaatu-ppbLlw โ€ข Oct 26, 2024
Hello all,
I have been trying to teach myself about microcontrollers and the like. I am at a bit of a loss though. Your help would be great.
I have a project where i would like to use IR to turn on/off a 3 watt LED.
The remote would need to be small (like the size of a watch) and the reciever would need to fit in an aluminum tube that is a 1 1/4 diameter. There will be a hole in the tube for proper LOS of the IR. These all will need to be power with batteries. The IR receiver will be activating a relay switch because the 3 watt will draw more power than the reciever set up (i would imagine)
I was at first looking at basic microcontrollers suchs as Motorola/freescale, AVR, and PIC. Then I stumbled upon the motorola encoders/decoders.
<a href="https://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&catalogId=10001&productId=287865" target="_blank" rel="nofollow noopener noreferrer">We are sorry but you have encountered an error</a>
<a href="https://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&catalogId=10001&productId=296702" target="_blank" rel="nofollow noopener noreferrer">MC145026P Encoder Motorola | Jameco Electronics</a>
So my question is should I go with microcontrollers or the encoder/decoders. I would think the encoder/decoders but would i still need to do some programming or are they precoded to work with one another? or is there a better way to do it?
Thank you all very much in advance.
  • sauravgoswami
    @sauravgoswami-UAfTlI • May 23, 2008
    buddy,we can do it with a 8051 microcontroller and IR decoder.no need of high-end Micorcontrollers or encoder/decoder.
  • just2rock
    @just2rock-DkmPtO • May 25, 2008
    Intel Microcontroller,8xc series...is the perfect match for what i underrstand for the said project
  • mkaras
    @mkaras-D7t19e • Jun 7, 2008
    Also consider that if you put a small MCU behind the IR receiver it can do the decoding in FW and then drive the output to control the lamp driver. For simplicity in your IR source (the transmitter end) consider using one of many cheaply available universal remote controls. This way you can avoid even having to build that portion.
    Here is a link to one such example:
