  • Installing a turbocharger in a 2 stroke engine?
    Reya
    Reya
    @reya-SMihdC
    Updated: Oct 23, 2024
    Views: 1.1K
    Hi friends!! Is it possible to install a turbo charger in a 2 stroke engine?
  • Reya
    MemberSep 24, 2010
    Is there anyone to clear my doubt?
    AdministratorSep 24, 2010
    @Praveena: Its a great question. But I was just wondering, how did this question pop in your mind? (You being a Computer Engineer)
  • Reya
    MemberSep 25, 2010
    I was assisting my friend to search for the mechanical project titles..While surfing i came to know that installing a turbocharger in a two stroke engine is possible..I need some information about installing a turbocharger in a two stroke petrol engine.i googled but i could not find information based on my topic.
  • Reya
    MemberSep 26, 2010
    nobody there to help me??
  • Reya
    MemberSep 26, 2010
    I did not get you..
  • gohm
    MemberSep 28, 2010
    No need to bump your thread. Installing a turbo on a 2 stroke is difficult because of the design. The crank seals don't handle pressure well. You'd need an oil pump to assist in feeding lubrication to the lower end of the motor, normally done by the fuel mix. You would also have to solve the turbo interference with the expansion chamber as well as the reed valve (the pressure would try to force it open constantly).
  • Reya
    MemberSep 28, 2010
    Thanks gohm😀
  • ShrinkDWorld
    MemberSep 28, 2010
    @gohm=>
    will you plz expain the basic for turbocharger?
  • gohm
    MemberOct 3, 2010
    A turbo is a form of forced induction using a turbine powered by gases to increase the amount of air input into an engine. This increase of air density allows for an increase in power and torque output. There are coldside and hotside turbo systems. Wikipedia has a good basic breakdown here: <a href="https://en.wikipedia.org/wiki/Turbocharger" target="_blank" rel="nofollow noopener noreferrer">Turbocharger</a> .
  • HungryMinds
    MemberJan 3, 2011
    dude it can be done.... and i'm doing RND on my LML vespa .... n i did my first test using vacuum blower n my results were not at the expected level... so still i'm digging deeper....
  • HungryMinds
    MemberJan 3, 2011
    shivsankar0
    hello i m a mechanical engg student
    hello shiv shankar give ur opinion on this topic
  • reepu_s
    MemberJan 19, 2011
    u can install it ....but again thr occurs a problem on size and since the exhaust from a two stroke engine is not sufficient enough to run the compressor of turbo charger....so dont think its possible to achieve the required compression....
  • nikole
    MemberJan 25, 2011
    gg_gaurav
    @gohm=>
    ______________________
