@gohm-F3UUpP • Jul 8, 2008
I don't have an answer for this but can't wait to see other's ideas.
@kinetic-joules-Qk9kmk • Jul 8, 2008
frodo.rok, I LOVE your icon. . . I just thought I would throw that in there.
@maro-Ce3knx • Jul 10, 2008
Space tanks? connected with pipes to small tanks on earth as buffers, but don't know connection speed I mean the way Hydrogen would move up to the space tank & it's speed.
@patriotgordon-RiJriF • Jun 30, 2009
lithium-6 deuteride
particle accelarator
@voltaire-4MxWke • Jul 24, 2010
You need to compress it. Te higher the pressure the lower the volume you require. 11m3 for 1kg is at STP. You would definitely not store it under these conditions as the cost of the vessel would be greater than the cost of the gas ๐
@sourabhmahawar-C1iM2G • Jul 27, 2010
department of energy US is working on a project actively regarding using hydrogen as an energy carrier for future,and hydrogen storage is the most important prospect of this,several methords are proposed regarding h2 storage but the most promising one is storing h2 in metal hydrides,anybdy need information can contact at
and guys plz dont give silly answers.. -
@voltaire-4MxWke • Jul 31, 2010
Commercial hydride vessels operate at 10 bar. Desorption is achieved by pressure swing ๐
@billyy2288-JXUqBC • Sep 16, 2010
KINETIC_JOULESfrodo.rok, I LOVE your icon. . . I just thought I would throw that in there.
I also think so.
@ishan-nohePN • Jan 7, 2011
Why do you think it can't be stored in a small space?
Can't it be compressed? -
@martincrow-0TCTDa • May 27, 2011
No idea about this thing.
@ramani-VR4O43 • May 29, 2011
Hydrogen is a permanent gas. Can be compressed to any extent. Cost of compressing and storage can be high. A lot of research is going into reversible absorption.
<a href="https://www.hydrogen.energy.gov/storage.html" target="_blank" rel="nofollow noopener noreferrer">Hydrogen Storage : DOE Hydrogen Program</a>
#-Link-Snipped-# -
@gurjap-blPmg9 • May 30, 2011
I wanna store it in ice. just like methane can be stored in it. in the north and in the south, there are places (I mean the arctic and the antarctic) where ice can exist naturally and which are practically wastelands. I realize this sounds sorta crazy. I back it up with two links.
wheeeee heeeeee -
@jaxrobinson-27LwVb • Jun 21, 2011
Oh very difficult to answer..๐
@esha-marathe-JIiSUk • Jul 14, 2011
The nanotubes can condense and safely store high volumes of hydrogen in a small space
@syed-mosa-raza-dmglsh • Jul 27, 2011
by compression... v can also do this by creating a vacuum in d vessel...
@ramani-VR4O43 • Sep 12, 2011
An update:
#-Link-Snipped-# -
@ramani-VR4O43 • Sep 21, 2011
Another update:
#-Link-Snipped-# -
@alloyau-uY7LwS • Nov 12, 2011
If you compress hydrogen above a certain point it will spontaneously explode. It is a very risky game. Check out Bob Lazars website unitednucleardotcom, his product is a metal tube you fill with hydrogen under no pressure. The tube is made of a metal that is able to suck up hydrogen the same way a sponge sucks up water. When heating the metal to a point below 60 degrees celsius the metal releases the hydrogen accordig to Bob. His car runs only on hydrogen and he claims there is aboslutely no risk for explosion.
I have contacted the administrator to delete my sentence regarding spontenous explosion of hydrogen under pressure, my misstake.
@ramani-VR4O43 • Nov 13, 2011
AlloyauI have contacted the administrator to delete my sentence regarding spontenous explosion of hydrogen under pressure, my misstake.
That is right. What does happen is that when highly compressed hydrogen is suddenly released into air auto ignition can happen.
Spontaneous Ignition of Pressurized Releases of Hydrogen and Natural Gas into Airโ
(Frederick L. Dryer, Marcos Chaos, Zhenwei Zhao, Jeffrey N. Stein, Jeffrey Y. Alpert, and Christopher J. Homer
Mechanical and Aerospace Engineering, Princeton University, Princeton, NJ)
Abstract: This paper demonstrates the รขยยรขยยspontaneous ignitionรขยยรขยย (autoignition=inflammation and sustained diffusive combustion) from sudden compressed
hydrogen releases that is not well documented in the present literature, for which
little fundamental explanation, discussion or research foundation exists, and
which is apparently not encompassed in recent formulations of safety codes
and standards for piping, storage, and use of high pressure compressed gas systems handling hydrogen. Accidental or intended, rapid failure of a pressure
boundary separating sufficiently compressed hydrogen from air can result in
multi-dimensional transient flows involving shock formation, reflection, and
interactions such that reactant mixtures are rapidly formed and achieve chemical
ignition, inflammation, and transition to turbulent jet diffusive combustion, fed
by the continuing discharge of hydrogen. Both experiments and simple transient
shock theory along with chemical kinetic ignition calculations are used to support
interpretation of observations and qualitatively identify controlling gas properties
and geometrical parameters. Although the phenomenon is demonstrated for pressurized hydrogen burst disk failures with different internal flow geometries, similar phenomena apparently do not necessarily occur for sudden boundary failures
of storage vessel or transmission piping into open air that have no downstream
obstruction. However, subsequent reflection of the resulting transient shock from
surrounding surfaces through mixing layers of hydrogen and air may have the potential for producing ignition and continuing combustion. Much more experimental and computational work is required to quantitatively determine the envelope of parameter combinations that mitigate or enhance spontaneous ignition
characteristics of compressed hydrogen as a result of sudden release, particularly
if hydrogen is to become a major energy carrier interfaced with consumer use.
Similar considerations for compressed methane, for mixtures of light hydrocarbons and methane (simulating natural gas), and for larger carbon number hydrocarbons show similar autoignition phenomena may occur with highly compressed
methane or natural gas, but are unlikely with higher carbon number cases, unless
the compressed source and=or surrounding air is sufficiently pre-heated above
ambient temperature. Spontaneous ignition of compressed hydrocarbon gases is
also generally less likely, given the much lower turbulent blow-off velocity of
hydrocarbons in comparison to that for hydrogen.
