@rohit330-DvfKyG • Feb 3, 2009
Which password you meant about? If its windows, you can use Erd commander
Key features:
· Boots dead systems directly from CD
· Easy, familiar Windows-like interface
· Intuitive Solution Wizard helps you select the right tool to correct your system issue
· Includes Crash Analyzer Wizard to pinpoint the cause of recent system crashes for repair
· Allows complete disk sanitizing/data removal with Disk Wipe utility
· Includes the Locksmith utility to reset lost Administrator passwords
· Includes FileRestore so that you can quickly find and recover deleted files
· Provides access to XP Restore Points on unbootable Windows XP systems
· Detect malware and other applications that may be consuming system resources
· Includes an Internet browser to facilitate downloading needed files and patches
· Compares key info on unbootable systems with that of a working system for diagnosis and troubleshooting
· Automatically identifies and replaces critical system files that have become corrupt
· Allows for formatting and partitioning of disks
· Provides emergency removal capability for faulty hotfixes
· Built-in network access to safely copy data to/from dead systems
· Repair and diagnostic tools located on Start menu
· Repair tools include System Restore tool, System File Repair, Service and Driver Manager, Hotfix Uninstall Wizard, Locksmith, Registry Editor, Explorer, Disk Management, and Command Prompt
· Data recovery tools include Disk Commander and FileRestore
· Diagnostic tools include Crash Analyzer Wizard, System Compare, Autoruns, Event Log Viewer, System Information, TCP/IP Configuration, and Logical volumes utilities
· Compatible with Windows NT, 2000, XP, and Server 2003
![[IMG]](proxy.php?image=http%3A%2F%2Fimg181.imageshack.us%2Fimg181%2F6123%2Ferdcommanderzz1.gif&hash=f1030f32cc5406fd80f0a3468a2e003d)
And for Bios password, just take out the cmos for 10 minutes. It will reset. -
@terencepogicute-871eHG • Feb 3, 2009
if you forgot your account password in some web host maybe try to answer the security question or if nothing happen try some hacker site but you need to pay for it... or cain, the software that recover the password.... hahaha but if you forgot the password of your computer, try this: when the computer is reboosting and then asking your password.
ctrl+shift+f8 (click all at the same time)
ctrl+shift+f8 😁:dance:
backspace
enter
also try this one...
1.start run
2.type "cmd" then enter
3.black screen will appear ( type "net user" without the quotation) then enter
4.type "net user (and the username of computer) then enter
5.type the password (this is the new password then) then enter
ok
hope you recover your password...
@priyank-180-7LVZgV • Feb 3, 2009
just restart ur pc whith out cmos cell...
@rama-krish627-LuiiO6 • Feb 5, 2009
Hi friend. I tried this but it is not working. If the system is not able to open without password then how can we enter into the system and open the run and cmd.
@rohit330-DvfKyG • Feb 5, 2009
rama_krish627Hi friend. I tried this but it is not working. If the system is not able to open without password then how can we enter into the system and open the run and cmd.
Did you try what i mentioned...? It will work for sure. Am using the same.
@engineer-vinay-vETp5V • Feb 6, 2009
I hv tried it but its not working.
@rohit330-DvfKyG • Feb 6, 2009
engineer_vinayI hv tried it but its not working.
well, which one you tried. The ERD commander will work for sure. 100% guarantee.
@nsrshridhar-IsEy9H • Feb 8, 2009
Probably try logging in to Safe Mode and if it asks for credentials.. Use the username as Administrator and leave the password blank. This worked for me.
@heart-hacker-nZz25T • Feb 10, 2009
nsrshridharProbably try logging in to Safe Mode and if it asks for credentials.. Use the username as Administrator and leave the password blank. This worked for me.
I agreee 😁
@little-y5fNfV • Feb 12, 2009
hi
first when u swich on the computer pl. press f8.
so aftr few sec it will go in safe state
chose safe state
enter on it
its open lot of directory to unable it........
then it shows one window look like old operating system
then click on start
conrol panel>user account>remove d password of that use account
ok
restart ur syste normally
