How to invert a pdf
Well As I was scanning the document I forget to note that the whole pdf was rotated 180 degrees and so if I oprn the file now all are inverted and it is really difficult to read them now
Do tell how to remove this error ? Without actually redoing the scan process
  • Anil Jain
    Anil Jain
    @CrazyBoy Aug 5, 2013
    ConquerorWell As I was scanning the document I forget to note that the whole pdf was rotated 180 degrees and so if I oprn the file now all are inverted and it is really difficult to read them now
    use the rotation feature if you have Adobe PDF Editor.
    If not, Press ALT + CTRL + down arrow (I know bad method, but that will resolve your problem for now.. 😁)
    This will invert your screen and you can read your document.
    To correct the screen hit ALT +CTRL + up arrow
    -CB
  • rahul69
    rahul69
    @rahul69-97fAOs Aug 5, 2013
    If u r using Foxit reader, go to View->Rotate View-> For other pdf readers, there will be similar feature, and the way told by CB is funny, but it will work 😁.
  • Jeffrey Arulraj
    Jeffrey Arulraj
    @jeffrey-xA7lUP Aug 5, 2013
    Well I want to save the rotated Pdf
    I tried all these steps before But when I save the default mode is only saving and not the actual editing
  • Jeffrey Arulraj
    Jeffrey Arulraj
    @jeffrey-xA7lUP Aug 6, 2013
    Is there a way I tried a method But that is like time consuming.
    I took images of the pdf file and then compiled them into another document to convert it back into pdf file
  • Nayan Goenka
    Nayan Goenka
    @nayan-Dhpt4N Aug 7, 2013
    Step 1: Take Screenshots of pages. Use Lightshot
    Step 2: Arrange all the screenshots in a powerpoint presentation
    Step 3: Rotate all the inserted images.
    Step 4: Save As pdf.
    Bingo!
  • Jeffrey Arulraj
    Jeffrey Arulraj
    @jeffrey-xA7lUP Aug 7, 2013
    Nayan GoenkaStep 1: Take Screenshots of pages. Use Lightshot
    Bingo!
    I found this is method is there otherwise any other possibility
  • cathyhill
    cathyhill
    @cathyhill-nOHQdu Feb 13, 2014
    Jeffrey SamuelWell I want to save the rotated Pdf
    I tried all these steps before But when I save the default mode is only <a href="https://www.rasteredge.com/how-to/vb-net-imaging/pdf-get-to-start/" target="_blank" rel="nofollow noopener noreferrer">VB.NET PDF: Get Started with PDF Library</a> and not the actual editing
    you must have adobe acrobat 3d or you can use word2007 to modify and save pdf files.
    more at #-Link-Snipped-#
  • Mrinmoy Swarnakar
    Mrinmoy Swarnakar
    @mrinmoy-swarnakar-pqfdvP Feb 13, 2014
    @#-Link-Snipped-#
    You can use "Nitro Reader " to solve your problem
    In Nitro Reader after rotating u can save it too.
  • macjone
    macjone
    @macjone-hv0aTS Mar 31, 2014
    Mrinmoy Swarnakar@#-Link-Snipped-#
    In Nitro Reader after rotating u can <a href="https://www.rasteredge.com/how-to/vb-net-imaging/pdf-processing/" target="_blank" rel="nofollow noopener noreferrer">VB.NET PDF: VB.NET Guide to Process PDF Document in .NET Project</a> too.
    Nice recommendation. I did not hear this reader before. Worthy of trying.😉
