  • How to interpret packets?
    Manish Goyal
    Manish Goyal
    @manish-r2Hoep
    Updated: Oct 11, 2024
    Views: 1.1K
    I have developed a program using JPCAP in java,which will capture packets and display it received by my pc but the problem is that output is not understandable by me
    when i execute that program and enter the url address in web browser say Google.com,it displays me output like this
    1277469255:706879
    1277469255:708581
    what does it means?Is there any possible way to extract header ,length ,type of packet and data that resides in that program
    This is my program
    import jpcap.*;
    import jpcap.packet.*;
    import java.io.*;
    import jpcap.packet.TCPPacket.*;
    import java.net.InetAddress;
    class NetworkList
        public static void main(String args[])throws IOException
            int i;
            try
            NetworkInterface[] devices = JpcapCaptor.getDeviceList();
            for (i = 0; i < devices.length; i++)
                  //print out its name and description
                  System.out.println(i+": "+devices[i].name + "(" + devices[i].description+")"+devices[i].loopback);
    JpcapCaptor captor=JpcapCaptor.openDevice(devices[0], 65535, false, 20);
    for(i=0;i<10;i++){
    System.out.println(captor.getPacket());
    captor.close();
    catch(Exception e)
    System.out.println(e.getMessage());
    I have also tried using captor.getPacket().data ,but then it throws null exception
  • Manish Goyal
    MemberJun 25, 2010
    guys i have achieved what i want 😀 I have used 2nd method ie callback method for this
    but still confused why there was exception in first case when i try to capture packets one by one
  • durga ch
    MemberJun 27, 2010
    did you try to goggle then with the error message you received?
    To interpret packets may be you can refer to this thread #-Link-Snipped-#
  • Manish Goyal
    MemberJun 28, 2010
    yeah i had searched on google about this ..
    But the error was same that i commonly encountered during programming in java
    ie null
  • Manish Goyal
    MemberJun 28, 2010
    Now again there is new problem
    Previously when i was using my broadband connection for accessing internet .I was able to capture packets, received by my system.
    but now when i am accessing internet using my mobile as a modem(usb modem) ,i am not able to see even single packet .
    can anyone explain me what's the reason?
  • durga ch
    MemberJun 28, 2010
    USB port numbers are different from your Ethernet port number right?
    can you explain your program above? I am a JAVA illeterate
  • Manish Goyal
    MemberJun 28, 2010
    I have used jpcap which is a open source library for capturing and sending packets from java applications
    To get the List of network Interfaces of my machine.jpcap provides JpcapCaptor.getDeviceList() method which is static method of JpcapCaptor class.It will return array of NetworkInterface objects and by using the fields of NetworkInterface class ,I can retrieve each and every information of networkinterface of my machine.
    JpcapCaptor captor=JpcapCaptor.openDevice(device[index], 65535, false, 20);
    Once we obtain the list of network interfaces and choose which network interface to capture packets from, you can open the interface by
    using jpcap.opendevice() method
    while calling openDevice(),we provide following parameters
    NetworkInterface interface:-NetworkInterface which you want to open
    int no:-Max no of bytes to cpature
    boolean promics :-Whether to open device in promiscuous mode or not
    int time_out:-to set capture time_out value
    Once you obtain an instance of of jpcapcaptor,you can capture packets from the interface.
    There are two major approaches to capture packets using a #-Link-Snipped-#
    instance: using a callback method, and capturing packets one-by-one
    In callback method we implement the interface named PacketReceiver then create a method named which will handle the packets gernerated
    For capturing packets we can use either processPacket() or loopPacket() method.
    For each captured packet it will call the method which i have created to handle that packet
    and in one by one approach .I will simply create a loop and capture packets by using getPacket() method
    I hope,you got an idea
    If still confused then post your query
  • durga ch
    MemberJun 28, 2010
    alright
    By what you have said - since its our network interface device has changed < i think the problem might be here
    "while calling openDevice(),we provide following parameters
    int time_out:-to set capture time_out value"
    this is a just a inference though.
  • Manish Goyal
    MemberJun 28, 2010
    But when i execute my program there is only one networkInterface it is showing on output, which i can open
  • durga ch
    MemberJun 28, 2010
    ..and which network interface does it show?
  • Manish Goyal
    MemberJun 28, 2010
    VIA RHINE II Fast Ethernet Adapter
  • Manish Goyal
    MemberJun 28, 2010
    I think the problem is with net connection .I am not sure whether this program works on dial up connection or not
