How to calculate inrush current?
Shyamsundar
Shyamsundar
@shyamsundar-dZmKP4 Oct 23, 2024
How to calculate inrush current? And what is the maximum limit of inrush current?
    @thebigk Dec 27, 2012
    Why not tell us your thoughts on how can the inrush current be calculated? Share your thoughts so that electrical / electronics engineering experts can help you.
  • Shyamsundar
    Shyamsundar
    @shyamsundar-dZmKP4 Dec 27, 2012
    The_Big_K
    Then without knowing the inrush current limit, how will you choose particular NTC thermistors as protection elements against inrush currents?
    I think calculation of inrush current can be obtained from the textbooks. Once you get the steps, you should be able to calculate the thresholds and continue with the further problem. Is there any problem you are facing with the inrush current related calculations? If yes, please post your specific problem so that it can be solved with the help of CEans 😀 .
  • Jeffrey Arulraj
    Jeffrey Arulraj
    @jeffrey-xA7lUP Dec 30, 2012
    You need to specify more about your ckt to imagine it and check for the maximum possible inrush current during spikes
