How close to edge, of unreinforced trench fill foundation, can wall be?
How close to an edge of unreinforced concrete trench fill foundation is it possible to erect a brickwork wall, say 140mm wide?
If the applied bearing pressure below foundation is lower than allowable soil bearing pressure when checked under eccentric loading it is, design wise, OK to erect a wall flush with the side of trench fill foundation.
However what about concrete cracking? Is there a rule saying that such and such distance from edge of concrete element should be maintained when applying a load to prevent unreinforced concrete from cracking?
Thanks.
