Help on image processing using matlab
naks4u
@naks4u-gRUMex Oct 27, 2024
HELO FRIENDS I AM THIRD YEAR ENG. STUDENT AND I AM WORKING ON IMAGE COMPRESSION AND FOR THE SAME I WANT TO CAPTURE A IMAGE FROM A CAMERA AND STORE IT IN TWO MY PC FOR FUTHER PROCESSING IS IT POSSIBLE IF YES THEN PLS HELP ME......
"Courage is not absence of fear , its to overcome that fear"
    @thebigk Feb 28, 2009
    Capturing image from a camera and storing it on your PC is easy. You could
    1. Use camera software and USB cable to transfer images to your pc.
    2. Use bluetooth (if available) to transfer images.
    3. Use the SD card reader.
  • naks4u
    @naks4u-gRUMex Mar 2, 2009
    thanku very much sir but is it possible to do real time image capturing using all these things i mean , i want that if i give some command then whatever the image which is in focus of my camera will be captured and store it in my pc so is it possible by the above mentioned stuffs
  • Predictor
    @predictor-lfVrRm Mar 14, 2009
    naks4uI AM WORKING ON IMAGE COMPRESSION AND FOR THE SAME I WANT TO CAPTURE A IMAGE FROM A CAMERA AND STORE IT IN TWO MY PC FOR FUTHER PROCESSING IS IT POSSIBLE
    I've had some success with <a href="https://www.yawcam.com/" target="_blank" rel="nofollow noopener noreferrer">Yawcam - Yet Another Webcam Software</a>, which will map the image sensed by the Web cam to the computer's filespace. Once Yawcam is set up and running, MATLAB programs can simply imread to grab images.
    -Will Dwinnell
    <a href="https://matlabdatamining.blogspot.com/" target="_blank" rel="nofollow noopener noreferrer">Data Mining in MATLAB</a>
  • naks4u
    @naks4u-gRUMex Mar 14, 2009
    thanks friend for replying now can any one tell me if i have more then one source for video and image capturing connected to my pc or lap simultaneously than how i can select a particular source and get the data in my workspace in matlab................
  • scurrminator
    @scurrminator-vGIQjz Mar 17, 2009
    yes its possible
  • just2rock
    @just2rock-DkmPtO Mar 17, 2009
    naks4u,
    let be brief you little amout image comression...hope you know todays advanced MJPG,MPEG4.these compression technologies are embedded in cameras of today.we had developed many & is on roll in our CCTV security industry. now if camera has inbuild feature like this its very ease to do nothing as such.
    Now if you use webcam & want to process same in Matlab it will be possible with single source multiple application algorithms..If you have any more queries go ahead
  • Asha T
    @asha-t-AT5t7E Oct 13, 2011
    RBC count in blood samples i m planin to do a project
    on image processing....but i wud like to do it in matlab code. ...can anyone help me regarding the code ...my mail id is <removed>
