Help me with C programs
abbd1990
@abbd1990-WLnI62 โ€ข Oct 25, 2024
Write a program that outputs all perfect numbers less than 1000
Write a program that inputs two fractions in the form a/b and c/d , and outputs their sum in the form p/q cancelled down to its simplest form ?โ€‹
Everyone - please enclose the code in
 ... [ /code ] tags
thank you
    @thebigk • Jan 6, 2009
    Re: help me with my c programmes
    Hi, How about showing us your efforts?
  • abbd1990
    @abbd1990-WLnI62 • Jan 6, 2009
    i can't solve those two programmes so that i post them here ๐Ÿ˜
  • shalini_goel14
    @shalini-goel14-ASmC2J • Jan 6, 2009
    abbd1990i can't solve those two programmes so that i post them here ๐Ÿ˜
    ok, not a problem. C users will post them for you here ๐Ÿ˜‰. By the way will Java programs work for you?
  • Ashraf HZ
    @Ash • Jan 6, 2009
    What biggie meant was, can you try typing the basic C structure first (eg the "#include" preprocessor directive)? Then we can see what area you are struggling at ๐Ÿ˜€ You'll learn better if you show us your attempts.
    Unless, you have no clue at all?
    I only wanted him to try. Once you know the formula for generating perfect numbers; rest is cakewalk.
    I'd still want him to post the incorrect program and ask CEans to guide him than looking for a ready-made program.
  • shalini_goel14
    The_Big_KI only wanted him to try. Once you know the formula for generating perfect numbers; rest is cakewalk.
    Even I also don't wanted to give him/her ready made program but I don't even want to give him/her a bad impression from this forum in the starting itself. I want him/her to be more active.๐Ÿ˜€
  • prakash.athani
    @prakashathani-RsvHp8 • Jan 7, 2009
    Hey abbd1990, check these two small programs. Are these two what you wanted? ๐Ÿ˜€
    C program to display all perfect numbers less than 1000
    #include <stdio.h>
    #include <conio.h>
    int main() {
                  int i,j,num,sum;
                  clrscr(); // To clear the screen
                  printf("The perfect numbers less than 1000 are:");
                  for(i=1;i<1000;i++) {
                         num=i;
                         sum=0;
                         for(j=1;j<num;j++) {
                                   if(num%j==0)
                                          sum=sum+j;
                         if(sum==num)
                                   printf("\n%d",num);
                 getch();
                 return 0;
    C program to accept two fractions in the form a/b and c/d and display
    #include <stdio.h>
    #include <conio.h>
    int main() {
                  int nr,nr1,nr2,dr,dr1,dr2,i;
                  char nrsign=' ',drsign=' ';
                  clrscr(); //To clear the screen
                  printf("\nFirst fraction :");
                  printf("\n\tInput Numerator:");
                  scanf("%d",&nr1);
                  printf("\n\tInput Denominator:");
                  scanf("%d",&dr1);
                  printf("\nSecond fraction :");
                  scanf("%d",&nr2);
                  scanf("%d",&dr2);
                  printf("\nYour Inputs:");
                  printf("\n\tFirst fraction : %d/%d",nr1,dr1);
                  printf("\n\tSecond fraction : %d/%d",nr2,dr2);
                  nr=nr1*dr2+nr2*dr1;
                  dr=dr1*dr2;
                  if(nr<0) {
                              nrsign='-';
                              nr=-nr;
                  if(dr<0) {
                              drsign='-';
                              dr=-dr;
                  i=2;
                  while(i<=dr){
                              if(nr%i==0 && dr%i==0){
                                      nr=nr/i;
                                      dr=dr/i;
                                      i=2;
                              else i=i+1;
                  printf("\nResult : %c%d /%c%d",nrsign,nr,drsign,dr);
                  getch();
                  return 0;
  • Ashutosh_shukla
    @ashutosh-shukla-ed4Ei4 • Jan 8, 2009
    Hey buddy you got the code but if you would have tried and posted incorrect code we all would have been much more happy anyways welcome to the forum and we hope better efforts from those joining in but if you have any problem we are always there to help you
  • abbd1990
    @abbd1990-WLnI62 • Jan 9, 2009
    thanks very much my friends for your kind help
