Grand Quiz Question #2
The 2nd Question of the #-Link-Snipped-# is as follows -
Q. Using basic geometry rules, find the value of 'x' in the following figure.
[Question is worth 15 CE-Coins]
You shall not use trigonometry rules such as sines and cosines.
find-x
HINT: The image has not been drawn to proportion. It is advised that you draw the diagram yourself before solving.
A few instructions -
1. Your answer should be the
value of x along with the approach you used to solve this problem.
We expect you to give a logical explanation of how you reached to the solution.
2. Answers with no explanation at all will be disqualified.
3. Just as we said before, the fastest to answer correctly wins!
  • Anoop Mathew
    @anoop-FRTf1L • Nov 2, 2011
    x is 20 degrees. Exterior Angle is equal to interior opposite angle. angle ART is 20, so x also becomes 20
  • Anoop Mathew
    I meant angle SRT is 20, not ART...Typing mistake.
  • PraveenKumar Purushothaman
    @praveenkumar-66Ze92 • Nov 2, 2011
    The answer is 20 degrees. I drew it using hand and measured it. I can also be done as this way.
    R = 100 = 80 + 80 + R.
    P = 10.
    Mid Pt = 180 - 60 - 70 = 130.
    So, 150 - 130 = 20!
    @thebigk • Nov 2, 2011
    Do NOT make assumptions, folks ๐Ÿ˜€
  • Sagar07
    @sagar07-LecI1i • Nov 2, 2011
    In triangle PQR, angle R=180-angle P- angle Q= 180- 80-80= 20....
    angle RTS is 90..
    hence in triangle RTS, angle RST=180- angle R- angle RTS=189-20-90=70
    angle PSQ=180-10-90=80
    hence angle TSQ=180- angle PSQ- angle RST=180-70-80=30
    in triangle TSO, x= 180-90-angle TSQ= 180-90-30=60
    assuming intersection point is o......
  • Sahithi Pallavi
    @sahithi-oJZaYj • Nov 2, 2011
    i can give you the explanation in this figure,
    so by considering the middle triangle,
    20+ (50-x)+ (150-x) = 180.
    220-2x = 180.
    40 =2x.
    x=20!
  • Sahithi Pallavi
    sorry, forgot to add this image X
  • bhavna gupta
    @bhavna-gupta-jMg3Om • Nov 2, 2011
    Let the point inside the triangle be taken as A
    In triangle PQR
    According to the property 1:all the sum of all the angles of a triangle is 180 or 360
    therefore, P+Q+R=180
    80+80+R=180
    R=20
    In triangle RSQ
    as above property.......R+Q+S=180
    20+20+S=180
    S=140
    Now,acc to the property 2:sum of all the angles made across the line is 180
    therefore,In triangle POS...
    S=180-140
    S=40
    Again In triangle POS..
    P+S+O=180
    10+40+O=180
    O=130
    now In triangle POQ
    P+Q+O=180
    70+60+O=180
    O=50
    In triangle RST
    R+S+T=180
    20+140+T=180
    T=20
    now acc to property 2:
    O in triangle SOT
    130+O=180
    O=50
    acc to property 2:
    O in triangle QOT
    O=130
    In triangle QOT
    t=30
    now acc to property 2: At T
    T of triangle RST+T of triangle SOT+T of triangle QOT=180
    20+T+30=180
    Therefore Final answer is....T=130.......
  • Sudha Warad
    @sudha-warad-BVJKlM • Nov 2, 2011
    By Z property angle T=70, Given PTQ angle =90, and RTQ=180 so x=180-70-90=20.......
    thats all.........
    Repeat: DO NOT make assumptions, please! :๐Ÿ˜€
  • CIVILPRINCESS
    @civilprincess-308hDv • Nov 2, 2011
    X is 60
    the triangles RST AND QST are similar... since QS=SR (OPPOSITE ANGLES ARE 20) and they have a common side ST. (SSA congruency)
    i.e. RTS = STQ. => 90
    X+30 = 90. => X=60.
  • CIVILPRINCESS
    untitled
    THE SIDEs I'VE marked (SQ and SR) are equal and one common side ST and one equal angle 20. so SAS congruency...
  • ultimate_k
    @ultimate-k-H1oP3v • Nov 2, 2011
    x is equal to 50 degree (trial and error method).
  • Guneet Khanuja
    @guneet-khanuja-aX8fYa • Nov 2, 2011
    x= 70 degree.
    method: let angle TSQ= y, and angle RST= z.
    therefore,
    y+z=140
    x+y=130
    z-x=10.
    and SR= SQ
  • eternalthinker
    @eternalthinker-Kvsi5Y • Nov 2, 2011
    Can't find a logical way to x!
    Appreciate the question anyways ๐Ÿ˜€
  • eternalthinker
    The thumbnail was from previous attempts to answer. Auto-saved!
  • lovejeet
    @lovejeet-etHdkD • Nov 2, 2011
    x=30...
    psq=180-spq-sqp=40------------A
    angle sot(o is the intersection of sq and tp)=50---------------B
    prq=20-----------------------C
    in triangle pts, pst=140-------------D
    THerefore, tsq=100...
    Therefore, x=180-100-50=30
    HENCE, X=30.
  • abhinaykumar
    @abhinaykumar-DQL43M • Nov 2, 2011
    by simple triangle method all angles in triangle= 180 using this equation we can solve the problem
    as we all can see there are two rightangled triangles
    using those we can say the angle of x is 20
  • sunil pal
    @sunil-pal-bU2LM6 • Nov 2, 2011
    triangle STR&STQ
    ST=ST
    angle SQT=angle SRT
    in triangle SQR SR=SQ
    so angle RST=angle TSQ
    angle RSQ=140=angle RST+angle TSQ
    so angle RST = angle TSQ=70
    in triangle SPQ
    angle PSQ=40
    and angle PTQ=30
    and
    X+angle PTQ=90
    so
    X=60 ANS
    X=
    @abrakadabra • Nov 2, 2011
    Entries for this question are now closed.
    Check out today's question between 6pm to 9pm IST.
