@johnpeter-nyAlS2 • Oct 8, 2009
in india the gengrating stations are constructed according
to the distances but in the forgein countries the generating
stations are built according to the climate and the distance.
Thank you,
<edited> -
@manish-r2Hoep • Oct 8, 2009
hey are you talking about bandwidth???
@stephen-c-oHT7Ug • Oct 12, 2009
johnpeter is right and goyal he is talking about elctricity. It is the frequency at which the AC mains in our country alternate.
@just2rock-DkmPtO • Oct 12, 2009
anudoon098why frequency in india is limited to only 50 hz
A very good question.....
AC mains as you had seen is with 50Hz frequency .This is basically for India as our hydel/thermal plants regenerate power at that scale from bio-source.
Cant it be generated above or below 50 Hz?
Yes they can but corresponds to the sinusoidal variance of the AC source the tolerance is huge when compared to 50Hz scale.
U.S however operate on 60-80 Hz with 240 VAC where they are again maintained in the +-5 % tolerance scale.
I believe you got your query clarified & we look forward to many more brain hunting from you! -
@debu-62iszV • Oct 12, 2009
just2rockU.S however operate on 60-80 Hz with 240 VAC where they are again maintained in the +-5 % tolerance scale.
I don't think that is correct. North America uses 110-120v at 60Hz. For more information read <a href="https://en.wikipedia.org/wiki/AC_power_plugs_and_sockets" target="_blank" rel="nofollow noopener noreferrer">Ac Power Plugs And Sockets</a>
Regards,
Debu -
@webworld-bBuB63 • Oct 14, 2009
I'm not sure if its all correct!!!!
A lot of points are factored when a utility decides to choose 50 or 60 hz, sometimes it may even been a political rather than a technical one (we have seen various types of wars on measurements types of units used or have been an interested but an innocent invitee in format wars in electronics like 8 track v/s cassette, v2000 (an excellent system) V/s the betamax (also with some notable features)and the vhs. Now we are also extended into the video disc formats.
However if we were to look closely many of us will agree that 60hz is a good choice. It is more efficient, there will be less hum. All inductors and motors could be smaller, and the benefits will encompass a wide array of electical and electronic goods to which the changes will almost be transparent. (Even the pictures on our tv's will be more pleasing to look at minus the pronounced flicker). But it should be noted that most critical and large capital intensive plants and machineries, including certain medical equipment, will not take too kindly to such a change, which, besides straying from the critical specs, or worse still may give up altogether, unless expensive time-consuming replacement or an equally complicated and efficient cycle converter is installed before the system is connected to the mains. Offhand a lot of people may be for it, but are the others and the equipment willing to agree for it?
