is it possible for a light material to float in mid air if it both rotates and has a constant velocity (terminal velocity) of the material design0
Member • Aug 25, 2012
The terminal velocity is related to size, shape and density. A sheet of lead can float in a light up current if beaten thin and shaped properly. It does not have to rotate.
Are you sure? This action cannot be undone. -
I'm having difficulty connecting the phrases "float in mid air" and "has a constant velocity."
Aren't they mutually exclusive?Are you sure? This action cannot be undone. -
It is the differential velocity that matters. In a thermal (or in any medium the object is falling), if the upward velocity matches the terminal velocity the object appears to float in a fixed position.KenJacksonI'm having difficulty connecting the phrases "float in mid air" and "has a constant velocity."
that is it then can we really make a very light object of larger diameter to floatbioramaniIt is the differential velocity that matters. In a thermal (or in any medium the object is falling), if the upward velocity matches the terminal velocity the object appears to float in a fixed position.Are you sure? This action cannot be undone. -
Not quite. Every heavier than medium object has a settling velocity. If it is lighter than it will have rising velocity. There has to be a counter velocity like a thermal up current or a thrust mechanism to overcome this.jeffrey samuelthat is it then can we really make a very light object of larger diameter to floatAre you sure? This action cannot be undone. -
so precise calculations and tolerance to external impacts have to be seen before we can apply it
thanks sirAre you sure? This action cannot be undone.
