Finned tube heat exchanger
yl4896
@yl4896-GnmCGP โ€ข Oct 17, 2024
Hi,
I am doing the project of water preheater for a thermal oil heater under my factory.
Could anyone kindly share with me how to calculate the heat transfer area for the finned tube based on the fin height,fin thickness and etc.?
TQVM for your help..๐Ÿ˜
  • Rohan_sK
    @rohan-sk-7ZbDkK • Aug 29, 2009
    The heat transfer area for the fin can be calculated from any standard Heat And Mass Transfer book.
    Anyways,
    In general the fins have a greater cross section at the base where the tempreature is maximum to allow quick heat transfer and the area gradually reduces along the fin length.
    Also increasing the fin length unnecessarily wont help because eventually the heat conduction gradually reduces along the fin length. So try to keep your fin thicker at the base and reduce its area of c/s along the length and keep the fin length optimum to avoid wastage of material.
    Again the spacing between the two cnsecutive fins must be optimised so as to allow maximum heat transfer rate from the fin to the ambient fluid where heat is rejected.
    This will depend on the maximum tempreature at base, the cooling desired and the coefficient of convective heat transfer of the medium where heat is rejected.
    The thermal gradient for different type of fins is given in all standard books and you can refer any one of these to cater your needs. The governing equation can be easily found from there which fits your operating conditions.
    All the Best.
  • jhbalaji
    @jhbalaji-AH60JJ • Aug 31, 2009
    Yeah well said Rohan
