@gohm-F3UUpP • Feb 10, 2010
You mean like a hot side turbo?
@shrinkdworld-WWdBBc • Feb 11, 2010
surely deude but you have lose in efficency as there was problem in exhaust gases
070790vivek OP
@070790vivek-09g1Yf • Feb 11, 2010
gg_gauravsurely deude but you have lose in efficency as there was problem in exhaust gases
i did not understand how there is a loss in efficiency?:sshhh: -
@parul-saxena-uCRdk9 • Feb 17, 2010
this device is known as TURBOCHARGER.The exhaust gases are first allowed to expand in the nozzles.During this expansion ,Kinetic energy is obtained,that is used to drive the rotor of turbine,called the exhaust gas turbine.The combination of a supercharger driven by an exhaust turbine is also known as TURBO-SUPERCHARGER.
070790vivek OP
@070790vivek-09g1Yf • Feb 18, 2010
PARUL SAXENAthis device is known as TURBOCHARGER.The exhaust gases are first allowed to expand in the nozzles.During this expansion ,Kinetic energy is obtained,that is used to drive the rotor of turbine,called the exhaust gas turbine.The combination of a supercharger driven by an exhaust turbine is also known as TURBO-SUPERCHARGER.
yes it is used in 4 wheeler
but i want to use it in two wheeler for increasing efficiency.
but that's a nice comment.๐
welcome to CE -
@anupam-sonkar-F713eM • Feb 18, 2010
i think that energy can be used in other type of work with help of turbine
well it is good idea
with the help of turbine you will produce a kinetic energy and this energy can be used in the mobile charging or other thing like that. -
@rohith-shankar-camVus • Feb 20, 2010
bikes do not produce enough exhaust gas pressure
you wont get enough power to do useful work
