  • Execute your C program code without <stdio.h> and <conio.h>
    Koushal Patel
    Member
    Updated: Oct 26, 2024
    Views: 1.3K
    Anybody tried running C Program without the use of the header file declaration? If you are using Turbo C compiler, please let me know what is the output. Run any random program! Is there any chance of not using these header files and run the program error free? Want to learn!
  • rahul69
    MemberJan 29, 2015
    Koushal Patel
    Header-files are included to do the messy work for you, You can avoid header file declarations if u are going to do it by yourself.
    For example, if u want to use clrscr() for clearing the screen,but don't want to include <conio.h>, u can use system call directly using the function system("cls");
    inside your program. 😀
  • pratap singh, upendra
    MemberApr 7, 2015
    rahul69
    What are the other possible system calls that can make our life easier? I am asking for basic systems calls only.
  • Vishal Sharma
    MemberApr 8, 2015
    proffy
    By system call he means, the command prompt commands as far as I understand the post. To execute those commands you anyway need to require or include stdlib.h header as system() is defined in that header
  • rahul69
    MemberApr 19, 2015
    Vishal0203
    You are correct. But it was just an abstract example to emphasize on the concept rather than the actual underlying process of conversion, explaining which would have added to the confusion (with the details of macro implementations etc.)
    proffy
    You can call any command which can be used in our command prompt, eg:
    echo, ping etc.
  • Rahulkumar200
    MemberMay 2, 2015
    YOU CAN RUN PROGRAMS WITHOU USING <CONIO.H>.
    LIKE THIS:-
    [HASHTAG]#INCLUDE[/HASHTAG]<STDIO.H>
    INT MAIN()
    PRINTF("LIKE THIS");
    and many more!!!!!!!!!!!!!1
