engines aggragated technical data
sani11
@sani11-v0GTZw โ€ข Oct 26, 2024
Hi everyone!
I am trying to make a presentation concerning up to date internal combustion engines for different applications (light duty/passenger cars, heavy duty, marine/low rpm, aviation etc). I don't need any charts just sheer numbers of power, capacity, weight, engine dimensions, consumption(lt/h)/BSFC(g/kW). I tried to google them, but apart from the fact that the data I found were incomplete (e.g. I couldn't find engine weight and dimensions for passenger cars), it is also impossible to check every engine one by one (light duty applications alone may consist of hundreds of engines). So, I would be really grateful if someone could provide me with any source of information (books, technical papers, data bases etc.) that would have all these technical data aggregated (e.g. in the form of tables). Thank you in advance!
  • Shashank Moghe
    @shashank-94ap1q • Feb 25, 2015
    This has details for all the production automotive engines for most vehicles, hope this helps. Does not have the engine weight though.
  • sani11
    @sani11-v0GTZw • Feb 25, 2015
    Shashank Moghe#-Link-Snipped-#
    Thanks a lot!!!
  • n1kh1l
    @n1kh1l-4gY0qq • Feb 28, 2015
    sani11Hi everyone!
    Wartsila-Sulzer RTA96-C turbocharged two-stroke diesel engine
    Designed to provide the motive force for a variety of supertankers and container ships, it comes in 6 cylinder in-line through to a whopping 14 cylinder version. The cylinder bore is 38 inches and the stroke is just over 98 inches. Each cylinder displaces 111,143 cubic inches (1820 litres) and produces 7780 horsepower. Total displacement comes out to 1,556,002 cubic inches (25,480 litres) for the 14-cylinder version.
    At a length of 89 feet and a height of 44 feet, the total engine weight is 2300 tons - the crankshaft alone weighs 300 tons.
    The RTA96C-14 can achieve a maximum power output of 108,920 hp at 102 rpm and astonishingly, at maximum economy the engine exceeds 50% thermal efficiency. That means, more than 50% of the energy in the fuel is converted to motion. Its Brake Specific Fuel Consumption (BSFC) at maximum power is 0.278 lbs/hp/hr.
  • n1kh1l
    <a href="https://jalopnik.com/watch-how-they-assemble-the-worlds-most-powerful-diese-1537731918" target="_blank" rel="nofollow noopener noreferrer">Watch How They Assemble The World's Most Powerful Diesel Engine</a>
  • sani11
    @sani11-v0GTZw • Mar 2, 2015
    Once again thank you all! I haven't found anything about the weight of the automotive engines yet (which is my biggest problem) but I will keep searching. I found also an interesting address about motorcycle technical data which it even has power to weight ratio for some engines. I post it in case someone else needs it.
