Doubt on altering a car
viky1147
@viky1147-Ru5Vmg โ€ข Oct 26, 2024
Hey Guys, Can we replace the tyre of a car with some other tyre (with different thickness)...? I love the body design of Suzuki Swift. But i want the tyre thickness to be increased. can it be done? Waiting for ur reply's ๐Ÿ˜€
    @thebigk • Mar 16, 2012
    As far as 'can' is concerned, it should be possible. But from my common sense based guess; I think it will affect the overall performance of the car.
  • ISHAN TOPRE
    @ishan-nohePN • Mar 16, 2012
    The_Big_KAs far as 'can' is concerned, it should be possible. But from my common sense based guess; I think it will affect the overall performance of the car.
    What is your logic? Unable to get it.
  • CE Designer
    @ce-designer-BWq0yl • Mar 16, 2012
    I think it can be done. Thicker tires may be harder to turn while parking and while driving at low speed because you would have more surface contact and therefore more traction. Also, i am not sure of how thick you are thinking of going but be careful because with thicker tires you run the risk if touching your fender or front bumper when you lock or turn. This is why cars designed to take broader tyres usually come with a body kit that flares the fenders and bumbers.
    Advantages of wider tyres are better traction and better performance on wet road. You will have to get rims to match the thickness though ๐Ÿ˜Ž
  • ironman
    @ironman-EwX7JE • Mar 25, 2012
    Also you would be shelling out more for petrol. This is because the car has to produce more power to overcome the tyre-road friction due to the increased surface area.
