    @thebigk • Oct 16, 2015
    Karan007What is the difference between inductance and induction?
    Have you referred to any electrical engineering book yet? You will find plenty of information about the two if you make a search on Google. If you still have problem understanding the difference, you may ask specific questions. Good luck! ๐Ÿ˜€
    @abrakadabra • Oct 19, 2015
    Agree with what's written above. If you ask "what is xyz" all that people can do is give you a definition, which is never helpful to truly understand the subject.
    Instead point out what part of it you don't understand or find confusing.
    The process of generating electrical current in a conductor by placing the conductor in a changing magnetic field is called electromagnetic induction or just induction.
    Inductance is the property of a circuit whereby a change in current causes a change in voltage in the same circuit.
