Difference between exit and exit(0)
monkey_007
monkey_007
@monkey-007-UgQZQk Oct 26, 2024
I would just like to know that what is the difference between exit,exit(0) and exit(1).Please help me.
  • Vishal Sharma
    Vishal Sharma
    @vishal-pysGmK Oct 5, 2012
    you'll have a better explanation here...
  • Jeffrey Arulraj
    Jeffrey Arulraj
    @jeffrey-xA7lUP Oct 5, 2012
    exit needs one argument of type integer that means any number in the integer category can be sufficient for it
  • Vishal Sharma
    Vishal Sharma
    jeffrey samuel
    Not agreeing with your answer! PS the link above. you'll have the proper information about it 😀
  • sulochana anand
    sulochana anand
    @sulochana-anand-OrGmKr Oct 5, 2012
    exit and exit 0 or exit with non 0 numbers are used to terminate program.exit 0 is used to terminate without any error.but with nonzero it indicates eroors.for eg if u r trying to open file which is not exist in system then it may be indicated by some numbers like 1 etc.different types of eroor are indicated by diffrent numbers.
  • Aniruddha Varma
    Aniruddha Varma
    @aniruddha-varma-wWzjB7 Oct 19, 2012
    Not just the system, but even manually - you may put exit(1) into your code if you want to exit and also indicate an error to the OS.
    As I know it, most people just use exit(0) to mean that the program has terminated normally.
