DESIGN AND FABRICATION OF FLYING COPTER
Project Abstract / Summary : COPTER IS FABRICATED BY USING GEARS. THREE GEARS ARE MERGED WITH EACH OTHER WITH THE HELP OF ONE MOTOR. ONE MORE MOTOR IS USED IN THE OPPOSITE SIDE OF TWO PROPELLER, TO MOVE THE COPTER IN FORWARD AND REVERSE DIRECTION. THE COMPONENTS USED INSIDE THE COPTER ARE EQUALLY BALANCED TO FLY. THIS IS A NEW VERSION OF TRI-COPTER.
Why did you choose to work on this project topic : TO REDUCE COMPONENTS INSIDE THE COPTER AND TO ADD FEATURES. INVESTMENT IS LOW COMPARE TO NORMAL COPTER,LIFE OF THE COPTER IS HIGH COMPARE TO NORMAL COPTER,DESIGN IS SO SIMPLE AND EFFICIENT.IT IS SOMEHOW DESIGNED WITH MECHANICAL GEARS TO REDUCE THE MOTORS.THIS COPTER IS GOING TO BE USED IN THE AREAS OF DETECTING METAL COMPONENTS AND TO BE USED AS SPYCOPTER.
Project Highlights : THIS WOULD WIN IN THE CONTEST DEFINITELY,BECAUSE OF ITS NEW VERSION AND OF ITS NEW FEATURES.INVESTMENT IS LOW COMPARE TO NORMAL COPTER,LIFE OF THE COPTER IS HIGH COMPARE TO NORMAL COPTER,DESIGN IS SO SIMPLE AND EFFICIENT.IT IS SOMEHOW DESIGNED WITH MECHANICAL GEARS TO REDUCE THE MOTORS.
Institute/College Name: MADURAI INSTITUTE OF ENGINEERING AND TECHNOLOGY
City: SIVAGANGAI
State: TAMIL NADU
