cygwin gcc problem.
meeran
@meeran-rxMtFb โ€ข Oct 26, 2024
Hi...
I am trying to compile a c file using gcc in cygwin shell. But i am getting an error "no input file".. I have checked the path for nearly hundred times.. The path name is cent percent right and the file exists...
My problem is pictured below,
C:\cygwin\bin\gcc -Wall -O2 "/cygdrive/c/virtutech/src/misc/cygwrap/cygwrap.c" -o "/cygdrive/c/virtutech/src/misc/cygwrap/mysimics/cygwrap.exe"
gcc: /cygdrive/c/virtutech/src/misc/cygwrap/cygwrap.c: No such file or directory
gcc: no input files
Can anyone help me to get out of this situation.... Please....
  • KenJackson
    @kenjackson-mBf7HF • Oct 12, 2011
    I see you are using backslashes for the command path. Are you running this in Windows CMD or a Cygwin bash?
    You really should be working in bash, but it might work in CMD.
    In CMD, try getting rid of the quotes ("). I think CMD will pass them to gcc, whereas bash would consume them.
    Otherwise, what's your current directory? Can you cd to /cygdrive/c/virtuech/src/misc/cygwrap? And then run this:
    gcc -Wall -O2 cygwrap.c -o mysimics/cygwrap.exe
    Also, does the mysimics directory exist?
  • meeran
    @meeran-rxMtFb • Oct 13, 2011
    Thank you very much Ken...
    Actually i am not manually doing this process.. I have to create a workspace for my simics simulation project.. I gave the below command in my cygwin bash shell in order to create a workspace....
    "MEERAN@RABIYATHRAJA-HP ~$ /cygdrive/c/virtutech/bin/workspace-setup.bat mysimics
    The above batch file do various task to create a workspace as below.
    Setting up Simics workspace directory: mysimics
    Created directory: C:\cygwin\home\MEERAN\mysimics
    Created directory: C:\cygwin\home\MEERAN\mysimics\.workspace-properties
    Created directory: C:\cygwin\home\MEERAN\mysimics\modules
    Compiling 'cygwrap' wrapper
    o "/home/MEERAN/mysimics/cygwrap.exe"
    gcc: no input files
    The last four lines where the workspace-setup.bat tries to compile the cygwrap is the place of war here. I have checked the path of cygwrap.c and it exists. And the compile operation is automated not manual...
    Please help me...
  • KenJackson
    @kenjackson-mBf7HF • Oct 13, 2011
    Is the virtutech directory under C:\ or under C:\cygwin\?
    Your .bat file is saying it's under C:\.
    GCC is being executed, but it can't find the file, so that path must be wrong.
    My first guess is that virtutech is really under C:\cygwin, not C:\.
    If that's the case, just delete "/cygdrive/c".
    gcc /virtutech/src/misc/cygwrap/cygwrap.c ...
    Otherwise, verify that path. Something in it is wrong.
    BTW, using a .bat file guarantees you are using the Windows CMD shell instead of bash.
    That can work, but it's a shame. Bash is wonderful. I encourage you to use it.
