  • Current carrying capacity of capacitors in parallel
    Prakash Parmar
    Prakash Parmar
    @prakash-parmar-fN6I9f
    Updated: Oct 22, 2024
    Views: 1.0K
    if we connect to or more capacitors in parallel then what changes in its current carrying capacity?? like increase or decrease?? and why??
    Prakash Parmar
    Capacitor stores voltage only. And in case of capacitor when you connect in parallel its value increases.
  • Prakash Parmar
    MemberJun 15, 2012
    godfather
    what about the current carrying capacity???
  • Sindhu Chowdary
    MemberJun 16, 2012
    Prakash Parmar
    i think capacitors are storage devices......
  • pavani abburi
    MemberJun 16, 2012
    i=c dv/dt ....in parallel combination capacitance increases so c increases hence the current increases.
    Capacitors store charge. Paralleling just arithmetically adds up total capacity.
  • Prakash Parmar
    MemberJun 17, 2012
    thanx to all...
  • vikaskumar11233
    MemberJun 19, 2012
    Very knowledgeable discussion.In parallel current increases in capacitors.
  • Prakash Parmar
    MemberJun 19, 2012
    vikaskumar11233
    current increase or current carrying capacity increase????
    Neither. A capacitor stores electric charge. Coulombs. One coulomb = one ampere second. That is the amount of electric charge transferred when one ampere passes for one second.
    Similar to an overhead water tank. The water is just held in the tank. When a pipe connected to the tank is opened water flows, which is analogous to current in a wire. If you have two water tanks of 100 litres capacity connected in parallel you get a total capacity of two hundred litres.
  • rohit_jun22
    MemberJun 20, 2012
    capacity of the capacitor will not change. neither current carrying nor voltage storing. joining two capacitors in parallel simply passes less current through each capacitor than one capacitor across the same supply
