Creating Search Engine: MySQL Warning
manojsinghrana
@manojsinghrana-NciZJa โ€ข Oct 26, 2024
hello,
i am creating a search engine..
and i am getting an error
Warning: mysql_fetch_assoc(): supplied argument is not a valid MySQL result resource in c:\wamp\www\major project\search.php on line 22
in the command written below
sql_select_db ("music_park");
$get= mysql_query("SELECT * from searchengine");
while ($getrow= mysql_fetch_assoc($get))
//explode our search
$search_explode = explode(" ", $search);
foreach ($search_explode as $search_each)
//construct query
$x++;
if ($x==1)
$construct .= "keywords LIKE '%$search_each%'";
else
$construct .= "OR keywords LIKE '%$search_each%'";
//echo out construct
$construct = "SELECT * from searchengine WHERE '$construct'";
$run = mysql_query ('$construct');
$foundnum = mysql_num_rows('$run');
if ($foundnum ==0)
echo "no result found";
else
echo "$foundnum result found! <p>";
please somebody help me out to remove this error..
thank you very much...!!!
  • Manish Goyal
    @manish-r2Hoep • Jan 3, 2011
    Re: warning message
    which database are you using for this?
  • manojsinghrana
    @manojsinghrana-NciZJa • Jan 3, 2011
    Re: warning message
    hello,
    if you are asking me the name of my database then it is music_park.
    and i am working on wampserver.
  • Manish Goyal
    no i am asking are you using mysql or something else
  • silverscorpion
    @silverscorpion-iJKtdQ • Jan 3, 2011
    Wamp server uses MySQL only..
    Well, I don't see mysql_connect function being used to connect to the database first.
    If you have used it in the code before, fine.
    Also, use mysql_select_db instead of sql_select_db. That seems to be the only mistake to me.. try it.
    You can also try printing the result of your query to know if the query is actually executed or not.
    After the mysql_query line, just include a line to print the variable get.
    $get = mysql_query("SELECT * from searchengine");
    echo $get;
    Now you'll know what is stored in the variable when you are running the while loop.
  • manojsinghrana
    @manojsinghrana-NciZJa • Jan 16, 2011
    yes i am using mysql.
  • garima8905
    @garima8905-SQF1uJ • Oct 15, 2011
    sir, please help me to make a project in search engine in asp.net.
  • garima8905
    Re: warning message
    can you help me by guiding me how to make a search engine.?
