CrazyEngineers Archive
Old, but evergreen and popular discussions on CrazyEngineers, presented to you in read-only mode.
@Bull • 23 Jul, 2009
Hi!
How can we convert pressure energy to kinetic energy????
@silenthorde • 23 Jul, 2009
Hi Bull (that sounds weird)
Pressure is not a form of energy. Pressure is Force applied on a body per unit area. If you want to convert pressure into kinetic energy, it's equivalent to saying that you are applying a force on a body and you want motion.
If you apply Force on a body, it will move and so you will have KE, unless it is resisted by a equal and opposite force (Newton's law). ;-)
Hope this helps
Hope this helps
@raj87verma88 • 23 Jul, 2009
Yes.
Eg. Steam Turbines where the potential energy of steam (High temperature and pressure) is converted into Kinetic Energy.
Similarly, in internal combustion engines, where the high pressure of gases are used to push the piston which in turn moves the crankshaft and the wheel, thereby providing motion and hence kinetic energy.
Thanks!
So silenthorde how to convert that kinetic energy into electrical energy.
https://www.crazyengineers.com/forum...ring/27282-conversion-kinetic-electrical.html ...this was already discussed in one of your threads
@chinku51 • 25 Jul, 2009
The original form of Bernoulli's equation valid at any point along a streamline is:
where:
v is the fluid flow speed at a point on a streamline, Ψ is the gravitational potential, p is the pressure at the point, and ρ is the density of the fluid at all points in the fluid. H = h + v^2/ 2 g,
![[IMG]](proxy.php?image=http%3A%2F%2Fupload.wikimedia.org%2Fmath%2Fa%2F5%2F8%2Fa58b68f3bb891d015f4b62ad34e4a014.png&hash=34368753f529613a3c31a6939b3be262)
Force Force x length work Energy 1/2(mv^2)
Pressure = -------- = ---------------- = ----------- = -------- = ----------
Area Area x Length Volume Volume Volume
so,
pressure= KE/Volume
so,
pressure= KE/Volume
9.9k views
@Ankita Katdare · Jan 13, 2015
We could witness the day when Lithium-Sulphur batteries replace the Li-Ion batteries. The department of chemistry at the University of Waterloo has a team working on inventing a cheap, lightweight,...
3.8k views
@qaisarpk1 · Apr 1, 2009
what is the reason of negative resistance in UJT . plz explain in some detail
5.8k views
@Ankita Katdare · Jun 25, 2014
If you want the benefits of a laptop and a tablet in a single device, the all new gadget from Intel called - 'Education 2 in 1' might just be...
4k views
@pratap singh, upendra · Jun 16, 2013
I recently learnt that the best color to make an umbrella for use inn summers is to have white surface on the top and the bottom surface painted black.
What...
6.7k views
@ISHAN TOPRE · Mar 20, 2011
Hi friends, you all must have seen cameras in old movies. It used to be like a black-box coveredwith a black cloth. If this is not enough the photographer himself...
10.7k views
