@aarthivg-HH344f • Apr 3, 2012
One unit of electricity is exactly equal to 1000 Watts of power used for 1 hour.IssueDoes 1 unit of electricity stand for 1Wh? -
one watt is the rate at which <a href="https://en.wikipedia.org/wiki/Electrical_work" target="_blank" rel="nofollow noopener noreferrer">Electrical Work</a> is done when one <a href="https://en.wikipedia.org/wiki/Ampere" target="_blank" rel="nofollow noopener noreferrer">Ampere</a> of current flows through an electrical <a href="https://en.wikipedia.org/wiki/Potential_difference" target="_blank" rel="nofollow noopener noreferrer">Potential Difference</a> of one <a href="https://en.wikipedia.org/wiki/Volt" target="_blank" rel="nofollow noopener noreferrer">Volt</a> .IssueHow to convert any quantity to KWh if voltage, frequency and Current is given?
Say, my refrigerator has rating 230V, 50Hz, 1.1A. What is the KWh rating?
W= V*I -
Apparent power is expressed as VA unit, product of rms voltage and rms currentIssueAlso what does VA unit mean?
VA -voltage-ampere -
@shreyas-yx6FwP • Apr 3, 2012
All calculations are given for single phase AC loads at homes such as refrigerators,heaters,etc:
Power (KW)= Voltage (V) x Current (A) x Power factor / 1000IssueHow to convert any quantity to KWh if voltage, frequency and Current is given?
Energy (KWh)= Power (KW) x Time (Hrs)
Power factor for AC supply of 50 Hz is normally assumed to be from 0.6 (worst) to 0.8 (still bad!)
Apparent Power (VA) = Real Power (W) / Power factorIssueAlso what does VA unit mean?
Real power (W) represents the actual energy transfered from source to the load.
As the loads (refrigerators, heaters,etc) are inductive in nature, there is an additional component of power which is not actually transferred to load to do any fruitful work. This component is called reactive power and circulates back and forth between load and source. The net addition of reactive power (VAR) over any full cycle is zero. Eventually, these two components of the power taken from the source add up to apparent power (VAR).
1 unit = 1 KWh
