Complete The Series: 56, 90, 132, 184, 218, _ ?
Complete the sequence​56, 90, 132, 184, 218, __​(a) 368 (b) 316 (c) 362 (d) 326​
I tried a lot but couldn't get around solving this question.Can somebody please help me...?​
    @abrakadabra • Apr 28, 2012
    #-Link-Snipped-# you might be able to find a solution here.
  • suman.mathad
    @sumanmathad-EVll15 • May 1, 2012
    according to the alternate number explanation, the answer should be 288, but the answer is 326 as given in the soutions of a general intelligence paper. do write the explanation, if you come to know !
  • kookyhere
    @kookyhere-ui2w7I • May 7, 2012
    Nick_SharmaComplete the sequence​56, 90, 132, 184, 218, __​(a) 368 (b) 316 (c) 362 (d) 326​
    i think the answer should be 316..
    Solution(just a guess):
    1. divide the numbers by 8
    2. the reminder yu get fr the first 3 numbers is 0, 2, 4 respectively
    3. then again the reminder fr the 3rd and 4th number is 0, 2.. so the the next numbers' reminder should be 4.. hence it should be 316..
    Absolutely a wild guesssss😒. tell me if i am wrongg
  • Reya
    @reya-SMihdC • May 7, 2012
    #-Link-Snipped-# You're right 😀
  • Neeraj Sharma
    @neeraj-iAaNcG • May 7, 2012
    But I saw at a place on internet that the answer is 326 but don't know how 😛
  • kookyhere
    Nick_SharmaBut I saw at a place on internet that the answer is 326 but don't know how 😛
    ha.. if no clue how that 326 is the answer.... then take 316 for granted 😉👍
  • zaveri
    @zaveri-5TD6Sk • May 14, 2012
    kookyhereha.. if no clue how that 326 is the answer.... then take 316 for granted 😉👍
    Since there is no other logical explanation , then you are right.
  • Prashanth_p@cchi
    @prashanth-p-at-cchi-rg0z63 • May 23, 2012
    I think that the answer is 326..................
    I believe the series should have been 56, 90, 132, 184, 248, __....... ​i.e the last option should have been 248.... Explanation: In this case, the difference between the 2 numbers will be 34,42,52,64... i.e. add 8 to 34 to make it 42 , then 10 to make it 52 and then 12 to make it 64... So, adding 14 next, we shall get 78. When 78 is added to 248 we get 326. Please correct me If Im' wrong.
    @thebigk • May 24, 2012
    The answer is 326,
    Explanation: <a href="https://www.wolframalpha.com/input/?i=56%2C+90%2C+132%2C+184%2C+248%2C" target="_blank" rel="noopener noreferrer">56, 90, 132, 184, 248, - Wolfram|Alpha</a>
  • Prashanth_p@cchi
    @prashanth-p-at-cchi-rg0z63 • May 24, 2012
    The_Big_KThe answer is 326,
    Explanation: <a href="https://www.wolframalpha.com/input/?i=56%2C+90%2C+132%2C+184%2C+248%2C" target="_blank" rel="nofollow noopener noreferrer">56, 90, 132, 184, 248, - Wolfram|Alpha</a>
    So, Now I can confirm that my above explanation is correct. 😀
  • Prashanth_p@cchi
    Then, that confirms my above explanation.
