Carnot Engine Problem
QUESTION
A Carnot Engine operating between 900 Fahrenheit and 90 Fahrenheit produces 40,000 ft-lb of work. Determine (a) the heat supplied, (b) the change in entropy during heat rejection and (c) the thermal efficiency of engine. (answers should be in BTU)
MY ATTEMPT
(a) 22.74 BTU
(c) 60%
Am i leading to correct answers
  • yadavundertaker mohit
    @yadavundertaker-0p3HBs • Oct 10, 2009
    LindellQUESTION
    MY ATTEMPT
    (a) 22.74 BTU
    (c) 60%
    I don't know in BTU but i atleast can try it
    T1=900 F
    T2=90F
    W=40,000 ft-lb
    n=(T1-T2)/T1
    (900-90)/900
    =98.88%
  • antenna
    @antenna-3JkwKK • Oct 10, 2009
    Yadavundertaker, youhave use that formula(1-t1/t2) with t in kelvin.
    Use that,you would get the right ans.Any way the efficiency of a heat engine can reach 60% to 65% at max.
  • Lliño Del Rosario
    @llino-f7euoM • Oct 11, 2009
    1 ft-lb = 9.478* 10^-4 BTU
    (a) 22.74 BTU
    W=N QH
    =.60(40000 ft-lb * (9.478* 10^-4 BTU / 1 ft-lb)
    = 22.74 BTU
    am i correct?
  • raj87verma88
    @raj87verma88-ZpL2Wn • Oct 11, 2009
    T1 = 755.222 K
    T2 = 305.222 K
    1) Heat Supplied Qc = nRT1 ln(Vb/Va)
    ab is the initial Isothermal path.
