Can anyone explain the exception concept in this JAVA program?
zia.sepsis
@ziasepsis-0NGPzn โ€ข Oct 23, 2024
import java.io.*;
public class new
String name;
BufferedReader reader;
reader=new BufferedReader(new InputStreamReader(System.in));
System.out.print("\n What is your name?");
try
name=reader.readLine();
System.out.println("hello,"+name+"!");
catch (IOException ioe)
System.out.println("I/o exception error");
can anyone explain the exception concept in this program?????
  • safwan
    @safwan-NH7W5Y • Aug 1, 2009
    hi zia .
    { sory for spamming }
    this is for shallini.
  • pradeep_agrawal
    @pradeep-agrawal-rhdX5z • Aug 1, 2009
    In the given code the readLine() method on object of BufferedReader is being called. This functions returns the string for the line read from the specified input stream and it throws an IOException if there is any error in reading data.
    Whenever any method declares the 'throws' clause (i.e., it declares that it can throw a particular exception) then the calling method should:
    - Either implement a try catch block to catch that exception like done in given code where calling method implements a try catch block to catch IOException.
    - Or the method should declare the 'throws' clause in its signature.
    -Pradeep
  • zia.sepsis
    @ziasepsis-0NGPzn • Aug 1, 2009
    pradeep_agrawalIn the given code the readLine() method on object of BufferedReader is being called. This functions returns the string for the line read from the specified input stream and it throws an IOException if there is any error in reading data.
    -Pradeep
    Thanks mate.... so do you mean that... if the user doesn't give any input, the catch block will be executed.. am i right with my view????
  • pradeep_agrawal
    zia.sepsisso do you mean that... if the user doesn't give any input, the catch block will be executed.. am i right with my view????
    No, the program will wait till user gives any input, it will not throw any exception. It will throw exception if there is some error in reading the input and at that time the catch block will be executed.
    -Pradeep
