Can any one help me with this code?
abbd1990
@abbd1990-WLnI62 โ€ข Oct 25, 2024
hi to all
please can u help me to find the problems in this program
this program will find the min element in quarter1 of square array and the max element of quarter3 and replace them
q1 , q2
q4 , q3
#include<stdio.h>
main()
 int a[10][10],i,j,min,max,lmin,lmax,n,m ;
 scanf("%d",&n) ;
 scanf("%d",&m) ;
 for (i=0;i<n;i++)
  for (j=0;j<m;j++)
   scanf("%d",&a[i][j]) ;
 for(i=0;i<n/2;i++)
  for(j=0;j<m/2;j++)
   min = a[i][j] ;
  for(i=0;i<n/2;i++)
  for(j=0;j<m/2;j++)
  if ( min > a[i][j] )
   a[i][j]=min ;
   lmin=a[i][j] ;
  for(i=n/2;i<n;i++)
  for(j=m/2;j<m;j++)
  max = a[n/2][m/2] ;
    for(i=n/2;i<n;i++)
  for(j=m/2;j<m;j++)
  if ( max < a[i][j] )
   a[i][j] = max ;
   lmax=a[i][j] ;
  a[i][j] = lmax;
  lmax = lmin ;
  lmin = a[i][j] ;
  for(i=0;i<n;i++)
  for(j=0;j<m;j++)
   printf("%d",a[i][j] ) ;
  printf("\n") ;
thank u
  • silverscorpion
    @silverscorpion-iJKtdQ • Mar 22, 2009
    ah, you seem to have messed up the program in many places. I'll indicate the mistakes. Convince yourself that they are wrong..
    Lines 10,11,12 are not required. If they are executed, they'll simply assign a[n/2,m/2]
    to be the minimum number, which is not true. Instead, initialise min to a high number. Similarly for lines 18,19,20. Remove them and set max to a small number, say zero at the start.
    line 16: It should be min=a[j];
    line 17: It should be lmin=min;
    line 25: It should be max=a[j];
    line 26 is not required.
    there are many more. I'm posting the correct version of this program below.. Check it up.
  • silverscorpion
    #include<stdio.h>
    main()
    int a[10][10],i,j,min=99,max=-99,lmin,lmax,n,m ;
    scanf("%d",&n); scanf("%d",&m) ;
    for (i=0;i<n;i++)
    for (j=0;j<m;j++)
    scanf("%d",&a[j]) ;
    for(i=0;i<n/2;i++)
    for(j=0;j<m/2;j++)
    if ( min > a[j] )
    min=a[j];
    lmin=min;
    for(i=n/2;i<n;i++)
    for(j=m/2;j<m;j++)
    if ( max < a[j] )
    max=a[j] ;
    lmax=max;
    for(i=0;i<n;i++)
    for(j=0;j<m;j++)
    printf("%d\t",a[j] ) ;
    printf("\n") ;
    for(i=0;i<n/2;i++)
    for(j=0;j<m/2;j++)
    if(a[j]==lmin)
    a[j]=lmax;
    for(i=n/2;i<n;i++)
    for(j=m/2;j<m;j++)
    if(a[j]==lmax)
    a[j]=lmin;
    printf("\n\n\n") ;
    for(i=0;i<n;i++)
    for(j=0;j<m;j++)
    printf("\n") ;
    I've not commented the code as i'm sure you can understand it without trouble.
    Cheers!!
