C programming doubt ?
Sachin Jain
@sachin-0wuUmc โ€ข Oct 25, 2024
Hey guys,
If I execute the following code, what will happen ?
int *ptr;
ptr = malloc(100);
ptr++;
free(ptr);
Now ptr points to 2nd integer block.
Now if i use free ptr (as shown in code) what will it do ?
Will it free the whole 100 byte memory or something else ?
Please reply....๐Ÿ˜”
  • gaurav.bhorkar
    @gauravbhorkar-Pf9kZD • Jan 2, 2011
    I think it will crash the program because you have created an invalid reference to the block of 100 bytes of allocated memory.
    I'm not sure though. Did the program run?
  • csiscool
    @csiscool-qA5mGA • Jan 2, 2011
    Nice Question..
    this code results in memory leak.
  • Sachin Jain
    @sachin-0wuUmc • Jan 2, 2011
    @ csiscool
    Can you please explain more ?
  • nansijs
    @nansijs-Ulqfud • Apr 22, 2011
    I think the program cause memory leak. That is the allocated memory cannot be used by another application.
  • pradeep_agrawal
    @pradeep-agrawal-rhdX5z • Apr 26, 2011
    Based on ANSI C specification, if the argument passed to free does not matches with value returned by malloc/calloc/realloc, or if the space has already been freed by calling free or realloc then the behavior is undefined.
    With this i feel the behavior can be different based on the compiler being used. If the code is compiled using gcc then the program will crash at free itself.
    -Pradeep
  • vik001ind
    @vik001ind-rOaCSy • May 13, 2011
    int *ptr; // this is a pointer of int type
    ptr = malloc(100);
    /* ERROR - malloc returns pointer of void type (void *), it is incompatible typecasting.
    Correct statement - ptr = (int *)malloc(100); Here we are dynamically allocating an array of 50 integers (considering 16 bit compiler). */
    ptr++; // PTR IS NOW POINTING TO NEXT INT
    free(ptr); // ERROR - deallocating the pointer which contains the wrong address. Allocation of memory is done to different address.
    Program may result in segmentation fault. Memory leak is a different concept altogether.
  • PraveenKumar Purushothaman
    @praveenkumar-66Ze92 • May 14, 2011
    I got System Error and as said here, it caused a memory issue... Since I worked on a virtual machine, it crashed the system too. I used 64 MB of RAM and when I restarted it, it was fine. ๐Ÿ˜ It causes a Segmentation Fault! ๐Ÿ˜€
