@shreyasm89-jGobVm • Sep 27, 2010
Beautiful question!..😀...For this i think you will have to consider the internal circuit diagram of a npn transistor.Here since the base-emitter jn. is actually forward biased,the emitter being connected to -ve potential. So when the Ic(conventinal) flows in from the collector there is and additional atraction from the more -ve potential at emitter. This gives rise to current Ie which will flow throught he swamping resistor Re. -
@martin12-f28URR • Sep 29, 2010
Hello,
One of the more interesting aspects of an operational amplifier is that it can be used to perform mathematical operations electronically. Properly connected, an operational amplifier can add, subtract, multiply, divide, and even perform the calculus operations of integration and differentiation. These amplifiers were originally used in a type of computer known as the "analog computer" but are now usedin many electronic applications.
thanks!
<Donot put links -ES>
