what is function of fjywheel and what is it's application?0
Member • Jun 9, 2012
Flywheel is used to store energy produced during power stroke of engine so that energy can be used effectively in remaining three strokes. It is fitted just after crankshaft. It is widely used in automotive engines. Basic idea behind using flywheel is to get regular power.
Remember More is the number of cylinders in engine, lesser will be size of flywheel needed.Are you sure? This action cannot be undone. -
Member • Jun 10, 2012
so can be use flywheel in bike als?Are you sure? This action cannot be undone. -
so can we use flywheel in a bike? if not so why?Are you sure? This action cannot be undone. -
yes flywheels are used in bikes, because bikes always have single-cylinder engines due to lack of space.
anyways i think this topic has been discussed before in CE.Are you sure? This action cannot be undone. -
can we use more than one cylinder engine in a bike?Are you sure? This action cannot be undone. -
Yes ofcourse we can use more number of cylinders in bike e.g. Harley Davidson have V-Twin engines. Number of cylinders are decided on basis of power you require. But more be number of cylinders will make engine bulky and affect milege.Are you sure? This action cannot be undone. -
so there only one flywheel is required or more then one in muliti cylinder engine?Are you sure? This action cannot be undone. -
no engine will have more than one flywheel.jaspal rautelaso there only one flywheel is required or more then one in muliti cylinder engine?
as for v-twin engines , the flywheel size depends on the engine design.Are you sure? This action cannot be undone. -
so in bike, car or buses how many flywheel is used?Are you sure? This action cannot be undone. -
as i already told you, only one.jaspal rautelaso in bike, car or buses how many flywheel is used?Are you sure? This action cannot be undone. -
flywheel is a simple energy reservoir , the mass of the flywheel gives constant output of power to the final drive, flywheel can be used when there is need of constant output without any fluctuation of power while the input to the flywheel is intermittent from the source.Are you sure? This action cannot be undone. -
Flywheel is also employed in a punching press.Here there is constant input torque but the load is varying ,ie energy required at the time of punching operation is very high.Are you sure? This action cannot be undone. -
Member • Jun 25, 2012
Actually flywheel stores the energy which is more than the need of machine and releases it when energy supply lacks!
it stablizes the fluctuations in energy input.Are you sure? This action cannot be undone. -
One of the most basic function of flywheel is to store energy..this stored energy is exhausted in subsequent cycles.Are you sure? This action cannot be undone. -
Member • Jul 3, 2012
used to storage the energy by a mechanical way ..Are you sure? This action cannot be undone. -
Member • Jul 4, 2012
flywheel is a body of any arbitrary shape used to store the energy due to its heavy mass or in other words due to its moment of inertia so we can use it as a pusher. particularly this term is often used for round body but it is important to note that in many engineering application arbitrary shaped energy transverse devices are usedAre you sure? This action cannot be undone.
