ANSYS quite slow as compare with MATLAB, how to turn off its graphic display?
DanielChen
@danielchen-BRM77G • Oct 18, 2024
Dear all,
I am a newbie in ANSYS. I hope you are more familiar with ANSYS. So I wonder do you have any solution for the ANSYS problem that I have now.
In my case (1500 load steps for SDOF dynamic analysis), the processing time in ANSYS seems to be so much slow as compare to MATLAB. ANSYS takes more than 10 minutes while MATLAB needs only a fraction of second. The reasons might be ANSYS has to display all information at every load steps, both by text in Command Prompt screen also by graphics in the main screen.
I have taken so much time to look for the tips to turn off the interactive mode, turn off the temporary results graphic display, or to put the ANSYS run in the most priority mode, but I fail so far. There have no such tips for that purpose. Even that if I set the ANSYS processes to the Real time mode in Window Task Manager, my CPU usage is still about 20% when ANSYS run, and its speed is quite slow.
So if you know how to speed ANSYS up, please let me know. Thank you so much!!!!
P.S:
My platform is (laptop) Intel Core 2 Duo 2x2GHz, 2GB DDR3, 320 GB HDD, MS Window XP SP3, Matlab R2008a, ANSYS R11.
  • rebellionofrebel
    @rebellionofrebel-k3kf5Z • Nov 25, 2011
    Is ur OS 32 bit ????
    secondly, you are comparing two totally different software platforms..
    Matlab executes codes using a complier. tell me did u try using MAtlab to solve a structural problem of say bearing pedestal using a 3dof element?? try coding it ... its a PITA when u talk about coding complex probs in MAtlab..Its also possible that you have meshed your machine element in Ansys with a very fine meshsize. try to use larger Mesh and see the difference in time.If it still does not then I think you need to talk to experts why u ansys is slow.. but if u talking about ANsys as "SLOW" in front of MAtlab, then I m sorry to say ur comparison is totally invalid!!!!!
