Answer These Quiz Questions
gsk_ssit
@gsk-ssit-KY7Fvw โ€ข Oct 22, 2024
1)A person has 14 full filled bottle,14 half filled botttle and 14 empty bottles.He needs to share these for 3 persons equally.How he is going to do this?
2)A:B=4,B:C=9 then A:B:C=?
IF monkey climbs 1 feet per min and slips down 6 inches.At what time it climbs 11 feet?
3)If 2a+3b+6c=0 then 8a^3+2+b^3+2+6c^3=?
4) For very high speeds Which one would you prefer? Radial tire or Normal Tire
5)For very low speeds Which one would you prefer? Radial tire or Normal Tire
6)A shaft is failing to transmit a power from motor to pump.What we can do without changing the material or weight of the shaft?
7)Suppose a+b+c=12.if 198 is added,the numbers are reversed.What are the numbers?
    @thebigk • Dec 21, 2011
    Those are easy questions. Why don't you attempt them on your own?
  • gsk_ssit
    @gsk-ssit-KY7Fvw • Dec 21, 2011
    pl help these, i hve tried but i need to cross check
    gsk_ssitpl help these, i hve tried but i need to cross check
    Share your answers. We'll help you with the wrong ones.
  • gsk_ssit
    1)14 half full bottles
    2)...?
    Monkey problem...21 minutes
    3).....?
    4) radial tire for high speed
    5)normal tire for low speed
    6).......?
    7)A=9,B=3,C=0
    Pl see these answers are right or not .....pl share your answers if not right ....answer to ?
  • Dancer_Engineer
    @dancer-engineer-EJ8rGI • Dec 21, 2011
    gsk_ssit1)14 half full bottles
    2)...?
    3).....?
    6).......?
    7)A=9,B=3,C=0
    Your answers are not justified.
  • Sagar07
    @sagar07-LecI1i • Dec 22, 2011
    2)...?
    3).....?
    6).......?
    7)A=9,B=3,C=0
    1st answer is correct
    2)A:B:C=36:9:1
    monkey problem is also correct according to me...
    3)I dont think you have posted correct question..
    anyway, solution to such problems is like, you have to substitute 1 unknown in terms of other 2 and try to solve...
    4) and 5) i think, they are correct..
    6) i am not mechanical engineer, but according to me,you can use mechanical linkages like gears or rack and pinion....
    7) I didnt get the question, what do you mean by numbers are reversed???
  • gsk_ssit
    @gsk-ssit-KY7Fvw • Dec 22, 2011
    Sagar071st answer is correct
    2)A:B:C=36:9:1
    will you tell me detailed procedure for 2 nd one.Then 7 th question is like that only i also don know .....anyway for your reply
  • Sagar07
    Procedure is simple, see, U know when there are 9B, there is single C, so find out how many A are required for 9B i.e. single C,
    so, from 1st ratio, U get 36 A....
    hence, 36:9:1......
  • zaveri
    @zaveri-5TD6Sk • May 26, 2012
    answer to question number 6:
    reduce the weight of the shaft, but maintain a fail-proof diameter.
    the weight reduction reduces inertia.
  • Mohamed Sabil
    @mohamed-sabil-n2ZRsL • Jul 19, 2012
    1,7full bottles and 7empty bottles
    2,36:9:1
    3,21 minutes
    7,462 and 264
