    @thebigk • Jan 11, 2014
    'x = y' , which means Apple = Orange.
    @anoop-kumar-GDGRCn • Jan 11, 2014
    It's actually
    3*0 = 0
    @ramani-VR4O43 • Jan 11, 2014
    Anoop KumarIt's actually 3*0 = 0
    Right.
    The last but one step can be elaborated as 3 x 0 = 1 x 0. The fallacy is that dividing both sides by zero gives 3 = 1.
    Dividing by zero is an invalid operation.
  • zaveri
    @zaveri-5TD6Sk • Jan 12, 2014
    Check step number 5:
    it goes as 3X=X = 3Y = Y
    is this supposed to be 3X-X = 3Y - Y ?
    if it is, then the mistake occurs at step number 6.
    Step number 6 would correctly go as : 3X - 3Y = Y - X
  • micheal john
    @micheal-john-l1fIn3 • Jan 12, 2014
    1=3 is incorrect equation
    @thebigk • Jan 12, 2014
    The first line itself is wrong. When you say, 'x=y', which means 'x' and 'y' are one and the same thing. So it can be extended to any level and prove anything equal to anything.
  • micheal john
    Kaustubh KatdareThe first line itself is wrong. When you say, 'x=y', which means 'x' and 'y' are one and the same thing. So it can be extended to any level and prove anything equal to anything.
    yes
    @ramani-VR4O43 • Jan 14, 2014
    micheal johnyes
    Not really. X can be the number of girls in a class while y can be the number of desks in the class. The real issue is that division by zero is not a defined mathematical operation. The whole thing is set up as a confusing buzz, hiding the wrong operation.
  • madhu27
    @madhu27-Yq7VLh • Jan 17, 2014
    step1: x=y
    but in step5, 3(x-y)=(x-y)
    which means, 3(0)=(0)
    the mistake occurs here..😎
  • Shashank Moghe
    @shashank-94ap1q • Sep 15, 2014
    A.V.RamaniRight.
    Sir nailed it. Simple and elegant explanation.
  • shiwa436
    @shiwa436-h94d47 • Sep 16, 2014
    The above thing is just like.....
    If a=b , b=c then a=c
    Implies 2=root(4) , root(4)=-2 then 2=-2
    @ramani-VR4O43 • Sep 16, 2014
    shiwa436The above thing is just like.....
    Not really.
    In maths there is an equality and there is an identical equality.
    Both +2 and -2 are roota of 4.
    So 2 = Sqrt(4) does not mean 2 is identically equal to Sqrt(4)
  • shiwa436
    #-Link-Snipped-# ramani.. Sir,
    A small explanation will convince us, both the things are just outta incomplete application of actual rules....
    @thebigk • Sep 16, 2014
    This is the simplest explanation:
    The 'proof' starts by assuming 'X' = 'Y'. Since X and Y aren't defined -> you should be able to prove almost anything; because it's based on 'assumption' that X = Y.
    shiwa436#-Link-Snipped-# ramani.. Sir,
    Sqrt(4) = +/- 2
    Using Sqrt(4) to mean +2 in one part of the argument and -2 in another part leads to an inconsistency beca
    The original problem has a different issue. That argument uses division by zero, which is not permitted in maths.
  • Shashank Moghe
    @shashank-94ap1q • Sep 17, 2014
    Kaustubh KatdareThis is the simplest explanation:
    The problem is not the assumption. Mathematics gives us the full liberty to assume anything that fits the rules (and here assuming two variables are equal is not against any). The problem is the step (tricky step) which is so common to many such "proofs" which claim flabbergasting results to be true. This tricky step is intentionally introduced because it skips the attention of most amateur proof readers: and the step is called "division by zero", which is not defined.
  • uday ultra
    @uday-ultra-BDNYAg • Nov 26, 2014
    Rajni JainWhere is the mistake in the below explanation?
    1=3​
    below the 4th dot
