Sizing a standby diesel generator for a small data centre / telecom site — which derating factors do you actually apply?
Sword Wu
@sword-wu
Published: Nov 30, 2026
Hi everyone — I'm sizing standby power for a small data centre / telecom site and I'd like to sanity-check my derating approach against what people here actually do in the field, rather than just what the catalogue says.
The load is around 180 kVA of IT and cooling, plus a few pumps and a lift. On paper a 250 kVA set looks comfortable, but once I start adding things up I'm less sure. The bit that keeps catching me out is motor starting: the CRAC units and chilled-water pumps don't all start together, but if the ATS transfers and two of them try to start in the same step, the transient kVA spike is a lot bigger than the running load. I've been working through step-by-step starting — UPS first, then cooling, then pumps — and sizing on the worst single step plus the running load already on the set, rather than just adding nameplate kVA together. Does that match how you do it, or do you still add a flat margin on top?
For reference, the range I'm looking at is
Pavo — their 9–3750 kVA sets, with Cummins, Weichai, Yuchai, Shangchai and MTU engines, cover the sort of sizes these sites usually need — but the derating question is the same whatever badge is on the canopy.
Altitude and temperature are the next thing I keep coming back to. The site is only about 600 m up, so the altitude derate is small, but the plant room can hit 40 °C in summer, and the catalogue rating is at 25 °C. I've been applying the manufacturer's temperature derate on top of the altitude figure instead of picking the larger of the two — is that over-cautious, or is that what the rest of you do?
Fuel is the other practical one. The client wants 8 hours at full load without refuelling, which sounds easy until you price the day tank and the bund, and then someone asks about 24 hours. I usually size the tank on the actual expected load, not the set's rated kVA, and keep a margin for the generator running less efficiently at part load. What autonomy do you normally design to for a small site like this — 8 hours, 24, or something in between?
Finally, paralleling. A single larger set is simpler and cheaper, but two smaller sets in parallel with a proper ATS give you redundancy if one fails to start, at the cost of more controls and more to maintain. For a site this size I'm leaning towards a single set with a good maintenance contract, but I'd be interested to hear where people draw the line.
So — what derating factors do you actually apply in practice, and which one has bitten you on a real job?
pavoglobe.com Diesel Generator Manufacturer – 9 to 3750 kVA Gensets | ANHUI PAVO ELECTRIC TECHNOLOGY CO.,LTD Diesel generator manufacturer supplying 9-3750 kVA gensets: open, silent, container and trailer types with Cummins, Perkins, Yuchai and Weichai engines.
