viswasknit OP
@viswasknit-WWZ4XY • Sep 11, 2009
here i want give detail of my problem...
A xml file book.xml
<?xml version="1.0" ?>
<books>
<book>
<title>cobol</title>
<author>roy</author>
</book>
<book>
<title>java</title>
<author>herbert</author>
</book>
<book>
<title>c++</title>
<author>robert</author>
</book>
<book>
<title>coldfusion</title>
<author>allaire</author>
</book>
<book>
<title>xml unleashed</title>
<author>morrison</author>
</book>
<book>
<title>jrun</title>
</book>
</books>
Now i want a jsp page to take data of book.xml file..............
I use tomcat 6.018 as a server............... -
@sookie-T06sFW • Sep 12, 2009
JSP Part, I am leaving to you, if get stuck anywhere, feel free to ask. Below is how to read .xml file in Java file.
Pre-requisite: Knowledge of Parsers -SAX and DOM.
Taking your Books.xml example only
Books.xml
<?xml version = "1.0" ?>
<Books>
<book>
</book>
<book>
<title>java</title>
</book>
<book>
<title>c++</title>
</book>
<book>
</book>
<book>
</book>
</Books>Now how to retrieve this data in Java program. There are two approaches of doing so:
1. Using SAX [Simple API for XML]
package myjava; import java.io.File; import java.io.IOException; import javax.xml.parsers.SAXParser; import javax.xml.parsers.SAXParserFactory; import org.xml.sax.Attributes; import org.xml.sax.SAXException; import org.xml.sax.helpers.DefaultHandler; public class XMLReaderUsingSAX { public static void main(String[] args) throws IOException { String xmlFile = "I:/Books.xml"; System.out.print("XML file name:" + xmlFile); XMLReaderUsingSAX detail = new XMLReaderUsingSAX(xmlFile); } public XMLReaderUsingSAX(String str) { try { File file = new File(str); /*checks if the file exists */ if (file.exists()) { SAXParserFactory parserFact = SAXParserFactory.newInstance(); SAXParser parser = parserFact.newSAXParser(); System.out.println("XML Data: "); DefaultHandler dHandler = new DefaultHandler() { boolean title; boolean author; boolean mail; public void startElement(String uri, String localName, String element_name, Attributes attributes) throws SAXException { if (element_name.equals("title")) { title = true; } if (element_name.equals("author")) { author = true; } } public void characters(char[] ch, int start, int len) throws SAXException { String str = new String(ch, start, len); if (title) { System.out.println("Title:" + str); title = false; } if (author) { System.out.println("Author:" + str); author = false; } } }; parser.parse(str, dHandler); } else { System.out.println("File not found!"); } } catch (Exception e) { System.out.println("XML File hasn't any elements"); e.printStackTrace(); } } }Output:
XML file name:I:/Books.xmlXML Data:
Title:cobol
Author:roy
Title:java
Author:herbert
Title:c++
Author:robert
Title:coldfusion
Author:allaire
Title:xml unleashed
Author:morrisonIn above Java class, SAXParser class parses the XML file using parse() method. The characters() method prints data until value of element in startElement() is true
Characters(char[] ch, int start, int len) method retrieves identification of character data. The Parser calls this method and to report every character data encountered . If any error occurs it throws the SAXException. This method takes the following parameters:
- ch: This is the characters of XML document.
- start: This is staring position in an array.
- len: This is the number of characters to read from an array.
2. Using DOM[Document Object Model]
package myjava; import java.io.File; import javax.xml.parsers.DocumentBuilder; import javax.xml.parsers.DocumentBuilderFactory; import org.w3c.dom.Document; import org.w3c.dom.Element; import org.w3c.dom.Node; import org.w3c.dom.NodeList; public class XMLReaderUsingDOM { public static void main(String argv[]) { try { File file = new File("I:/Books.xml"); DocumentBuilderFactory dbf = DocumentBuilderFactory.newInstance(); DocumentBuilder db = dbf.newDocumentBuilder(); Document doc = (Document) db.parse(file); doc.getDocumentElement().normalize(); NodeList nodeList = doc.getElementsByTagName("book"); for (int s = 0; s < nodeList.getLength(); s++) { Node firstNode = nodeList.item(s); if (firstNode.getNodeType() == Node.ELEMENT_NODE) { Element firstElement = (Element) firstNode; NodeList fstNmElmntLst = firstElement.getElementsByTagName("title"); Element fstNmElmnt = (Element) fstNmElmntLst.item(0); NodeList fstNm = fstNmElmnt.getChildNodes(); System.out.println("Title: " + ((Node) fstNm.item(0)).getNodeValue()); NodeList lstNmElmntLst = firstElement.getElementsByTagName("author"); Element lstNmElmnt = (Element) lstNmElmntLst.item(0); NodeList lstNm = lstNmElmnt.getChildNodes(); System.out.println("Author: " + ((Node) lstNm.item(0)).getNodeValue()); } } } catch (Exception e) { e.printStackTrace(); } } }Output:
Title: cobol
Author: roy
Title: java
Author: herbert
Title: c++
Author: robert
Title: coldfusion
Author: allaire
Title: xml unleashed
Author: morrisonIn case 2, "book" is kind of hard-coded.
For more information about SAX and DOM, check following
Let me know, if you need any more details. Thanks !
