@aashish-VrevFC • Sep 15, 2009
It sounds like a good field. Not something I'd do research on (let's face it, I'm a mechie I couldn't make head or tales of the thing even if I wanted to 😁), but something I wouldn't mind paying for!! Imagine internet access wherever you want, in your terrace, in the middle of the ocean or on a trek in the himalays!! -
@durga-TpX3gO • Sep 15, 2009
thats all good😁 ! think of delay on transmission of voice? -
I hadn't really thought of that, but i'm sure our competent colleagues from electronics and computers will come up with something to address that as well!! -
@Ash • Sep 15, 2009
Well, you can technically have internet connection anywhere in the world (including north pole) using the Iridium constellation. It'll be slow.. but enough to post on CE 😛
Durga, do you mean using satellites as a backbone for Wimax? -
@ ash,
yup! Thats what i mean. -
didn't Iridum go bust?? (the company that made sat phones I mean) -
@Ash • Sep 15, 2009
Nope, they are still very much around.
Wimax via satellite would probably face the same issues as any other sat coms.. the issue of uplink speeds and coverage. But, if we are assuming that it is covering rural areas where an overland backhaul is expensive, then it does make sense. I think that would be the main purpose of combining both Wimax and satellite together anyway. -
yeah mostly to provide internet to sparsely populated areas where laying a fibre or for that matter erecting up a AP would be expensive. -
@Ash • Sep 15, 2009
Wait, won't you need to erect an AP for the Wimax node anyway? 😛 -
wait, if thats the case then whats the whole point of satellites coming into picuture! ?ashWait, won't you need to erect an AP for the Wimax node anyway? 😛 -
By AP do you mean access point?? Don't mean to sound like an idiot but, can't the satellite be used directly (circumventing the need for an AP) ?? I mean the satellite beams down data and a nifty little device on your laptop/netbook 'catches' it?? -
That's what I was thinking! 😛 This sure does need a readmad_scientistBy AP do you mean access point?? Don't mean to sound like an idiot but, can't the satellite be used directly (circumventing the need for an AP) ?? I mean the satellite beams down data and a nifty little device on your laptop/netbook 'catches' it?? -
found something similar
<a href="https://en.wikipedia.org/wiki/Satellite_Internet_access" target="_blank" rel="nofollow noopener noreferrer">Satellite Internet Access</a> -
@Ash • Sep 15, 2009
Yes, satellite signals can be beamed directly to the receiver, but they are very expensive and slow at uplinks.
Here's what I hypothesize the use of Wimax and Sat com together. Each user would have a cheap Wimax modem to be connected to the nearest Wimax base station (or access points). This base station (or a larger mobile station) will contain a high bandwidth transceiver with a high gain antenna, not unlike those used in TV ground stations.
Basically, the satellite component will replace the backhaul of the Wimax infrastucture. Different base stations can be scattered around the area without the need of backhaul cables linking each of them. -
@ ash,
you are talking about replacing the whole wired/unwired internet back bone with satellite structure is it? not a bad idea at all 😁, but what me and maddie were thinking (ok atleast what i was thinking) was, consider the resort areas/ housing colonies away from main suburbs in that case would employing a AP be a fair deal?
may be both the ideas can be combined, cater to such areas with satellite and let the satellites do the talking with other networks accessign internet. this would make the GEO satellites be a new techonlogy in internet communcation very similar to wireless communcation.
am i clear or did I confuse ? -
@Ash • Sep 15, 2009
Well, not replace the whole Internet backbone, just the Wimax infrastructure. Only the infrastructure that links the BTS with the network provider edge would be handled by the satellites. LEOs would be sufficient for this. GEOs are just too costly to use for rural operations.
That would be how I presume the use of both Wimax and Sat com together. -
@thejas-jeeth-jRprt5 • Sep 21, 2009
Hai very good morning ,
In fact i was very fasinated about the topic i,e the wimax. but really i didnt get its proper idea except the general veiw .so i need know mch about its practically implimented feilds or the devices developed with that technology . so if you have please do mail to my id that is < removed > -
@thebigk • Sep 21, 2009
No point in sharing your email ID. We request all the discussions to happen through the forums so that larger audience benefits.
