@tamil-7y6zGo • Mar 15, 2015
You just carefully watch the operation using single point cutting tool.
In single point cutting tool, only the tip of the tool is used for cutting. while grinding the tool, the edges also get sharpness, but the edges are not used for cutting. -
Sree Raj OP
@sree-raj-v22wgh • Mar 17, 2015
TamilazhaganYou just carefully watch the operation using single point cutting tool.
Sree Raj OP
In single point cutting tool, only the tip of the tool is used for cutting. while grinding the tool, the edges also get sharpness, but the edges are not used for cutting.Then why there is cutting edges?(principal and auxiliary cutting edges)
In case of drills it's not the chisel which is cutting, it is lips! Still called point! -
@tamil-7y6zGo • Mar 18, 2015
Sree RajThen why there is cutting edges?(principal and auxiliary cutting edges)
In case of drills it's not the chisel which is cutting, it is lips! Still called point!Drill bits are not single point cutting tools.
Sree Raj OP
@sree-raj-v22wgh • Mar 18, 2015
TamilazhaganDrill bits are not single point cutting tools.
Drills are not! But its cutting edges are called "Point",why so?
Sree Raj OP
see this picture, the point. -
Sree RajDrills are not! But its cutting edges are called "Point",why so?
For this fig, not only the point is used for cutting, but also the edges.
And here the point refers to the tip of the drill bit not the cutting edge. It may be the nomenclature. For slotting operation, the tool has two cutting point and cutting edge. this tool cannot be called as single point cutting tool. -
Sree Raj OP
TamilazhaganFor this fig, not only the point is used for cutting, but also the edges.
And here the point refers to the tip of the drill bit not the cutting edge. It may be the nomenclature. For slotting operation, the tool has two cutting point and cutting edge. this tool cannot be called as single point cutting tool.Can you suggest me a reference for this for a detailed study.
@ramani-VR4O43 • Mar 21, 2015
In the early days of mech engineering many terms were loosely used. As Tamilazhagan says above it is more a convention than actual engineering definition.
This attached ANSI document may help understand the current view. -
Sree Raj OP
@sree-raj-v22wgh • Mar 21, 2015
A.V.RamaniIn the early days of mech engineering many terms were loosely used. As Tamilazhagan says above it is more a convention than actual engineering definition.
This attached ANSI document may help understand the current view.Thanks a lot!
