@abhishek-fg9tRh • Sep 23, 2012
Because of flow of electric charge.
raviteja.s OP
@ravitejas-hppQgn • Sep 23, 2012
raviteja.sHow?
This flow of charge produces magnetic field B around the wire in shape of concentric circle. (consider a bar magnet & spill iron fillings on it .... the design you will see when iron fillings will be attracted to both poles will be concentric circles)
Now why this happens ... I dont know.
Maybe, some questions don't have satisfactory answers. -
@ramani-VR4O43 • Sep 23, 2012
#-Link-Snipped-# -
@ganesh-p-EPjflj • Sep 24, 2012
current is a flow of electrons and electron is a tiny magnet.so whenever the electron is in its excited state it exhibits magnetic properety.
@abhishek-fg9tRh • Sep 24, 2012
Electron is tiny magnet ?
You sure mate ?
Any element in universe consists of electrons .... As innumerable electrons persists in an small piece of element, it should have magnetic property because electron is tiny magnet as per you, right ?
Then why dont all elements persists magnetic property ? -
@durga-TpX3gO • Sep 24, 2012
these relate to field theories. Electricity and magnetic fields are closely related to each other and any change in electric field results in changes in magnetic field too. Hence flow in current results in a change in magnetic feild.
Ramani sir has provided with neat resources please refer them too -
Troll_So_HardElectron is tiny magnet ?
You sure mate ?
Then why dont all elements persists magnetic property ?all electrons will have that property,but the electron shoulb in motion to produce magnetic flux.
all the materials can not retain the magnetic properties.the materials in which the electron spin on its own axis will ony store magnetism like ,iron metal.some conductors will not magnetise ,but whenever the current is flowing in the conductor magnetic flux will develop across the conductor.in metals like copper and silver the electrons in the orbits only revolve around the nucleus but not spin around their own axis. -
who is remani air
durgathese relate to field theories. Electricity and magnetic fields are closely related to each other and any change in electric field results in changes in magnetic field too. Hence flow in current results in a change in magnetic feild.
@arunchary-VtqB3c • Sep 25, 2012
its because of Fleming left hand rule... a current carrying conductor produces a magnetic filed in perpendicular to an electric field.
@grsalvi-7IhIh1 • Sep 26, 2012
Consider these fundamental concepts.
1] A static electron produces only electric filed around it.
2] A moving electron produces only magnetic filed.
So in case of electric current which i nothing but flow(movement) of electrons a magnetic flux is produced. -
@henri-7eYVw8 • Oct 9, 2012
the magnetic effect of an electric current...the flow of electrons in one direction and current in the other produces the magnetic effect around the conductor....why i don't know
@grsalvi-7IhIh1 • Oct 9, 2012
Henrithe magnetic effect of an electric current...the flow of electrons in one direction and current in the other produces the magnetic effect around the conductor....why i don't know
check out.If you don't get ,ask. -
@vamsi-kancharla-kL9oxU • Oct 9, 2012
raviteja.swhy does current carrying conductor produces magnetic field?
due to flow of charged electrons in the conductor magnetic field is created it can be explained by AMPERE'S RIGHT HAND RULE
@jeffrey-xA7lUP • Oct 9, 2012
What is the difference then between a charged and uncharged electron here #-Link-Snipped-#
The general idea is this I guess as #-Link-Snipped-# posted when an electron moves in a conductor it causes a distortion in the electric field associated with it which results in a significant magnetic field to be generated
And by the by the electron in a fixed point also has some magnetic field associated with it along with the electric field around it never forget that -
@vamsi-kancharla-kL9oxU • Oct 10, 2012
A current carrying conductor, such as a metal wire, will produce a magnetic field around it because of the motion of charge within the wire itself. This motion produces or sets up a magnetic field around the wire in the form of concentric circles.
This electromagnetic effect is described in physics by the Biot-Savart Law, an experimentally deduced inverse-square law. The effect is also described by Ampère's Law, which is derived from the Biot-Savart Law. This law relates magnetic field and current.
Also, a magnetic field that is set up by an electrical current will produce a magnetic force. This force depends on the rate of charge transfer and the magnetic field.
The force produced by a current-carrying wire depends on the length, the magnetic field, and the current, which is the charge flow per unit of time. -
@jeffrey-xA7lUP • Oct 10, 2012
What exactly is charge here is it not electrons?
@grsalvi-7IhIh1 • Oct 10, 2012
You sure mate ?
Then why dont all elements persists magnetic property ?The thing is the magnetic moment of all atoms should have axis in same direction for net magnetic properties.May be this is the reason when current flows magnetic axis of all electrons get aligned in same direction.
@henri-7eYVw8 • Oct 12, 2012
that
aruncharyits because of Fleming left hand rule... a current carrying conductor produces a magnetic filed in perpendicular to an electric field.
that is a rule to show the direction of the magnetic field...similar to maxwel's cork screw rule....it does not explain how and why the magnetic effect is produced
vamsi kancharladue to flow of charged electrons in the conductor magnetic field is created it can be explained by AMPERE'S RIGHT HAND RULE
there is nothing amphere's right hand rule in physics,,,it is amphere's swimming rule which again shows on the deflection and does not explain the question
@payel-patel-Vcnk9C • May 24, 2016
exactly
what is d rison 4 magnetic effect -
@ramya-r-y3QIkf • Sep 22, 2016
Moving point charges, such as electrons, produce complicated but well knownmagnetic fields that depend on the charge, velocity, and acceleration of the particles. Magnetic field lines form in concentric circles around a cylindrical current-carrying conductor, such as a length of wire.
@my-Jxinug • Oct 25, 2018
Magnetic dipole present in every metal,
But when we flow the current in it than all magnetic dipole will be allined, so it show magnetic properties. Cause of allining (all dipole in same direction) of these dipoles.
@abhijeet-cBDXao • Oct 26, 2018
A current carrying conductor, such as a metal wire, will produce a magnetic field around it because of the motion of charge within the wire itself. ... Also, amagnetic field that is set up by an electrical current will produce a magneticforce. This force depends on the rate of charge transfer and the magnetic field.
@bishal-9MgsfY • Dec 6, 2018
<a href="https://funny-instagram-bios.blogspot.com">Thank you all for clearing my confusion</a>
@jeffrey-xA7lUP • May 12, 2023
The electrons move by distorting an electric field this distortion produces a magnetic field of significance
