    @thebigk • Apr 10, 2010
    Clutch is used to isolate the engine from the wheels; often while shifting the gears. I think clutch-less motorcycle you are talking about actually implements auto clutch that operates in accordance with engine speed.
  • raj87verma88
    @raj87verma88-ZpL2Wn • Apr 10, 2010
    Clutch is used to disengage and engage the transaxle and the engine.
    When we press the pedal it disengages and allows engine to run freely without transmitting power. In this position it permits the shifting of gears.
    While engaging it slips for a moment allowing smooth engagement and ess sock to drivetrain and transmission system. In engaged position it transmits power from engine to transmission.
    As far as clutchless bike is concerned. Will need to look at it before commenting on it.
  • raj87verma88
    The_Big_KClutch is used to isolate the engine from the wheels; often while shifting the gears. I think clutch-less motorcycle you are talking about actually implements auto clutch that operates in accordance with engine speed.
    I have doubts about it Biggie. Implementing auto-gearing with accordance with engine speed...ok thats possible, but how can auto-clutching work that way. I mean you are still manually changing the gears aren't you, but you are not engaging/disengaging the clutch manually. There must be something else.
  • ashishgupta652
    @ashishgupta652-nzpKVu • Aug 25, 2010
    hey thanxx buddy 4 ur answers but still i need more views .,.,as
    cant we change the gear without pressing the clutch,.,/?.,we can do,.,so why there is need of it,.,
    sry i was taking about automatic clutch system,.,so can u explain about it too,.in concern of it,
  • gohm
    @gohm-F3UUpP • Aug 26, 2010
    To my knowledge the only true clutchless systems in a car would be some EVs. Manual, auto, air/electronic, dual & cvt systems all use a clutch, although the driver may not operate it. In a manual system, you can indeed shift without the clutch (I do it sometimes on my bikes). If done correctly in certain situations and on certain transmissions, you can effectively shift without the clutch. It requires practice and good rev matching. Over time it will increase wear on the transmission. Replacing a clutch is a lot easier than rebuilding a transmission so really it is best to use the clutch.
  • Capt Spark
    @capt-spark-xvppcH • Aug 26, 2010
    Yes, the clutch is there to disengage the engine from the wheel (in manual transmission cars, obviously). If you press the brake paddle, the car has to stop, but the engine doesnt stop running. So you have to disenage the crank shaft from the main engine. That's what clutch does.
    You may manage to change the gear somehow without pressing your clutch pad, but cannot hit the brake without pressing it ๐Ÿ˜€
  • Capt Spark
    and clutchless vehicles are usually auto-transmission ones. they use fluid coupling or continuous (conical pulley type) ratio change mechanisms between the engine and the whees. You can search more about auto transmission mechanicsm in the internet
  • gohm
    @gohm-F3UUpP • Aug 27, 2010
    Actually in a manual transmission vehicle you can brake without depressing the clutch. It's referred to as trail braking. It is used to scrub off speed to slow down some without slowing down too much. Usually done at the entrance or during a turn. This way power is still going to the wheels so you do not unsettle the chassis and it assists in faster exit speed. On a bike I only pull lever in the clutch to downshift and once stationary while under braking, otherwise I am braking with the throttle closed. The added resistance of the engine via the wheel and transmission adds extra stopping power in combination with the brakes and is called engine braking. left foot braking is a braking means to slow the car without lifting off the throttle. Most modern braking systems are so powerful they can supersede directly proporsional throttle input. Most automatic transmission systems do not have a manual override (some do) so that using these techniques on an automatic will not prevent the clutch from engaging/disengaging.
  • abrahamselva
    @abrahamselva-ouykxc • Sep 3, 2010
    the main function of the clutch is to engage and disengage the power from flywheel to the gear box. In the rotary gear system i.e clutchless bikes contains every false neutral in between the gears like honda street, tvs jive.
  • Ramuk
    @ramuk-zuGiaW • Sep 4, 2010
    I think clutchless bike featuring rotary gear technology and a automatic clutch system
  • abhishek1814
    @abhishek1814-zNy1Ud • Sep 6, 2010
    clutch is used to disengage the wheel from engine.. and if you shift the gear without holding clutch then every time 0.03mm of the teeth of gear will be reduced. finally there will be problem in shifting the gear..
  • trulyajays
    @trulyajays-d05Isq • Sep 7, 2010
    when clutch is pressed the clutch plates gets engaged and the power transmission is reduced to engine, then the gear shifting takes place so that their might not be any problem in gear transmission also
  • ShrinkDWorld
    @shrinkdworld-WWdBBc • Sep 28, 2010
    In simple it is use to engage & disengage the driving shaft for shifting the gear!
  • dorramide7
    @dorramide7-RSnSgL • Oct 21, 2010
    Capt SparkYes, the clutch is there to disengage the engine from the wheel (in manual transmission cars, obviously). If you press the brake paddle, the car has to stop, but the engine doesnt stop running. So you have to disenage the crank shaft from the main engine. That's what clutch does.
    __________________
    <a href="https://www.youtube.com/watch?v=Nk2FvkGVoUY" target="_blank" rel="nofollow noopener noreferrer">- YouTube</a><a href="https://www.youtube.com/watch?v=Nk2FvkGVoUY" target="_blank" rel="nofollow noopener noreferrer">- YouTube</a>
  • sonia77
    @sonia77-lwRDIa • Oct 22, 2010
    no they do not. The cars go so fast they had to put in auto clutch, which changes gears automaticaly.You might crash if you changed gears manualy.
    Donot advertise_ES>
  • Saandeep Sreerambatla
    @saandeep-sreerambatla-hWHU1M • Oct 22, 2010
    @Sonia77 : Donot post advertisement links!
    if Interested email to admin(at)crazyengineers(dot)com
  • ashishgupta652
    @ashishgupta652-nzpKVu • Oct 29, 2010
    can the auto clutch and gearing system be introduced in cars?,.,it would only contain the accelerator paddle and brakes( like the activa or kinetic's)
    and the car can be started or stopped in any gear..,.,?
